Old 12-01-2022, 12:09 PM   #1
2020 27' Globetrotter
Cleveland , Ohio
15kwh of LiFePo4 Battery in GT27FB
Upgraded the batteries to 15kwh the under bed storage makes a perfect compartment for EV batteries, itís heated and insulated.
ID:	425905   Click image for larger version
ZeGermans is offline   Reply With Quote
Old 12-01-2022, 12:55 PM   #2
2007 16' International CCD
Somewhere , Colorado
Nice! I don’t want to diminish your very impressive installation, but isn’t that 1.5kwh? (15 100A)
field & stream is offline   Reply With Quote
Old 12-01-2022, 01:00 PM   #3
Cleveland , Ohio
Originally Posted by field & stream View Post
Nice! I donít want to diminish your very impressive installation, but isnít that 1.5kwh? (15 100A)
those are 16x 3.2V 304Ah cells... I run them as two banks @24V they all tested slightly over 304Ah so its 15kwh...
Old 12-01-2022, 01:07 PM   #4
2022 27' Globetrotter
DALLAS , TX
15,840 kw-hr in my GT 27FB Twin.
4x330ah Victron
See photo below. Taken during battery and inverter installation. Click image for larger version
foobar is offline   Reply With Quote
Old 12-01-2022, 01:10 PM   #5
Cleveland , Ohio
4x330ah Victron
See photo below. Taken during battery and inverter installation. Attachment 425907
The victron batteries are nice! But I paid 2200$ for the complete battery bank...
Old 12-01-2022, 03:21 PM   #6
Llittle54's Avatar
2016 16' Sport
Port Angeles , Washington
Tell us more!
Llittle54 is offline   Reply With Quote
Old 12-01-2022, 03:47 PM   #7
Llittle54's Avatar
2016 16' Sport
Originally Posted by Llittle54 View Post
Tell us more!
Eve from Gobel Power?
Old 12-01-2022, 05:28 PM   #8
"Cloudsplitter"
Tell us more!
"You can always tell a German, but you can't tell 'em much" Amanamos
ďListen, or your tongue will make you deafĒ Native American proverb.
Old 12-01-2022, 05:39 PM   #9
Cleveland , Ohio
They are EVEs 304Ah but I buy them from Docan in China. Have bought plenty there before for home solar system. They are hooked up to JK BMS with a 2A active balanced which integrates with the Victron Cebro. To balance weight I put a Victron multiplus in the other side bed storage…
Old 12-01-2022, 05:45 PM   #10
2015 28' Flying Cloud
Newtown , Pennsylvania
How do you charge that battery bank? And how long does it take?
Bruce
50 amp, Awning package
2015 Ram 2500 6.7 TD, Blue Ox 1000 lb.
4 Lifeline AGM, Trimetric 2020
PD9160 converter, Prosine 1800 inverter
2x eu2000i Propane
AstroBruce is offline   Reply With Quote
Old 12-01-2022, 06:13 PM   #11
Cleveland , Ohio
Originally Posted by AstroBruce View Post
How do you charge that battery bank? And how long does it take? Hi
Bruce
So I got 800w Solar on the roof which usually keeps it charged. I have a little generator I can top off if needed. Theoretically plugged in from 0-100% it takes about 9h.
When we travel distance a lot of times we drive in the evenings and work from the trailer during the day so even if the solar would not cover for the whole power consumed on not so nice days… the battery bank at least allows us to do this for a few days until we get to a destination where we check in at a campground…
For extended boondocking out west next year my next project are some diy foldable solar panels. To add another 400w or so…
Replacing lead acid w Battle Born LiFePO4 Deep Cycle Battery mortizaspen Batteries, Univolts, Converters & Inverters 23 04-16-2022 09:41 AM
Charged Voltage setting for Victron BMV-712 battery monitor with LiFePO4's? qwertyd10n Batteries, Univolts, Converters & Inverters 18 04-25-2021 11:26 PM
Do you disconnect solar or LiFePo4 battery when not using your trailer hovr Generators & Solar Power 4 01-01-2021 03:00 PM
Word of warning for LiFePO4 battery conversions (Battle Born) SilverHouseDreams Batteries, Univolts, Converters & Inverters 153 08-21-2020 05:13 PM
LiFePo4 battery + inverter install & solar prep 03bart 2016 - Current International 11 08-19-2020 06:23 AM
