05-08-2021, 12:00 PM
2008 31' Classic
Clifton
12 volt won’t send power to plugs
We are new to Airstream, love our 08 Classic. Wife wants her coffee after I have taken down shore power on moving day. She can’t use her coffee maker since the plugs are shut off without shore power. Is there a way for her to get juice out of a 110 wall plug to make her Java juice?
05-08-2021, 12:06 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
O Yes, but it’s a worm hole that might not be worth a cup of coffee. You will need a 3000 watt inverter and the switches and fuses to go with it.
05-08-2021, 12:36 PM
1994 34' Excella
Warren
, Manitoba
Airstream uses 2 different voltage systems. Wall plugs are 110 volt. Your coffee maker etc uses 110 volts. The 12 volt system runs the light , fans, and water pump etc. The trailer has a converter to convert 110 volt to 12 volts to charge the batteries when pluged into shore power, and run the 12 volt side of the trailer. Unless you have an inverter to change the 12 volt battery power back to 110 volt, when you are not on shore power, your coffee maker will not work. Suggest buying one of the 12 volt coffee makers for this situation!!
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
05-08-2021, 12:53 PM
2021 30' Flying Cloud
2020 25' International
minneapolis
Our 2020 Int & 2021 FC both are able to run our Nespresso machine, vacuum & toaster off of the inverter when not plugged into shore power. ...One at a time... The only appliance of ours that wont run off the OEM inverter is the microwave.
- Stewart
05-08-2021, 01:59 PM
2016 27' Flying Cloud
Hartsburg
, Missouri
So to summarize the replies above, yes if you have an inverter that is powerful enough for your coffe pot, but not all airstreams have an inverter. So you first need to detemine if yo have an inverter, and if it is powerful enough. Otherwise as GMFL indicated, you can consider modifications that would enable yoo to do this. Why not just boil water on your stove and use a pour over or french press?--Frank
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
05-08-2021, 02:03 PM
2014 25' Flying Cloud
Cuddebackville
, New York
Heat water on the LP stove and use a drip coffee maker or a percolator.
2019 Ford Expedition Platinum
2007 30' Classic S/O
Somewhere
, South Carolina
I posed your query to my best half. She's a coffee gotta have it type.
Her suggestion, disconnect shore power AFTER making the coffee.
05-08-2021, 09:00 PM
2022 28' International
Lakewood
Just a question, are there any 12 volt receptacles mounted within the interior of the Airstreams or outside? My former trailer had one in a compartment for the tire minder antenna and one for the TV area such as DC power supplies.
05-09-2021, 05:58 AM
2019 30' International
Pennsylvania
, Pennsylvania
I got the little champion generator out a couple weeks ago, while boondocking, hooked it up to a 20lb propane tank, fired it up, plugged the trailer in, all so my lovely wife could dry her hair
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
05-10-2021, 09:38 AM
1977 31' Sovereign
Bartlett
, TN
There is elegance in simplicity!
05-10-2021, 09:50 AM
Evergreen
If we aren't on shore power, we generally use an Aero Press or French Press with water heated up on the stovetop, or we fire up the generator and use the coffee maker. I don't like to bring the coffee maker along because it's big and bulky and it's a power hog. I thought about a Nespresso machine, but they're all 1,000W+ and I've only got a 1,000W inverter.
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
05-10-2021, 01:09 PM
Napa
if you get a very low powered coffee pot (less that 1000 watts) it will work. We tried that, it isn't the best coffee! Decided to go with a French Press -water heated on the gas stove. Ah, now we are awake.
05-10-2021, 01:16 PM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
We use a French Press when there's "no power"...or Starbucks Vias.
Shari
05-10-2021, 03:29 PM
1986 25' Sovereign
Southern Middle
, Tennessee
The last thing I do before pulling out of the site is pull the 30 amp plug and store it. All the other tasks are completed first. On a hot day you will be glad you wait to pull the plug.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
05-10-2021, 07:39 PM
1988 32' Excella
Robbinsville
, New Jersey
You could take the coffee maker outside and plug it into the pedestal.
05-10-2021, 10:54 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
I have lots of AC available, but I still prefer my "Camp Coffee" from a 9 cup percolator using the stove top. When its done I dump the filter and gounds then clean the innards. During the days stops I just reheat the coffee in the pot. After a few hours it really does get to the 'Camp Coffee" taste. I have enjoyed that taste for years.
guskmg
