RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 06-23-2017, 04:55 PM   #1
Alcoa Roller's Avatar
Dallas , Texas
12 volt question
I replaced one of those combination 12v/110ac light fixtures with a 110 only fixture. What do I do with the 12 volt lines that fed that fixture? There were two wires going in on twelve volt side. Hot and ground I assume. Can I just cap them and stuff in ceiling or will that effect something downstream? Thanks.
Alcoa Roller is offline   Reply With Quote
Old 06-23-2017, 05:10 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Just cut off any bare wire, tape them up, particularly the hot wire, and stuff them. No problems downstream.
Al
Old 06-23-2017, 05:22 PM   #3
Images: 59
Tape them up means separately, not together.
Old 06-25-2017, 06:45 PM   #4
Yep, thanks!
Al
12 volt
2 6 volt or one deep cycle 12 volt ErikFrolich Batteries, Univolts, Converters & Inverters 5 01-19-2013 01:27 PM
24 volt or 12 volt solar panels advantages?? purman Electrical - Systems, Generators, Batteries & Solar 13 09-06-2012 03:29 PM
6 volt vs 12 volt brakes? lwebb Brakes & Brake Controllers 17 07-14-2005 09:32 AM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 01:04 AM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 10:03 AM
