2 of 3 12 volt outlets not working in our 07 25' FB. Plugged a Fantastic fan into the outlet and it stopped working. The outlet is dead. If there is a fuse I sure can't find it. Appreciate and suggestions.
Pull the outlet and inspect the wiring. If you have a test light or multi-meter, use that to see if you have 12 volts coming to the outlet on the wires.
