Old 06-22-2020, 01:50 PM   #1
crestview , MI
12 volt help
Hi,
New to this world, so please bear with me.
I was switching out a couple 12volt light fixtures this weekend when I popped a breaker. I was stripping a wire with with a metal utility knife and touched the other wire. I've done this in my house before, just switched the breaker back on and off we go. Not this time.
It seems the manual reset didn't pop out at. I've pushed each one of them hoping something would reset. I've turned off all the power and unplugged from shore power.
So to fix it I need to buy a new breaker? right? What do I buy? It looks like they are riveted in place, how do you get them out? I don't have a meter to even tell which is bad.
The electrician, Mike from DryCampers, who did our solar suggested I replace the whole panel with Chunzehui F-1005 9 Port 40A Connector Power Splitter Distributor Source Strip, 1 Input and 8 Output.
I have no idea how to do that.
Next question, would you hire a local electrician to do it? Should I only trust people who work on Airstream?
thank you for your input!
Cate
2001 31' Excella
catesword is offline   Reply With Quote
12 volt
2 6 volt or one deep cycle 12 volt ErikFrolich Batteries, Univolts, Converters & Inverters 5 01-19-2013 12:27 PM
24 volt or 12 volt solar panels advantages?? purman Electrical - Systems, Generators, Batteries & Solar 13 09-06-2012 02:29 PM
6 volt vs 12 volt brakes? lwebb Brakes & Brake Controllers 17 07-14-2005 08:32 AM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 09:03 AM
