Old 10-05-2022, 09:35 PM   #1
2021 20' Basecamp
Seattle , Washington
12 v electrical diagram
Is there a good source for the 12 v electrical diagram for a 2014 Bambi Sport 16? I may have blown a fuse by shorting out some wiring for the lights in the rear bedroom area and the closet but don't know which fuse might have blown (none of the enunciator lights on the panel have illuminated)
thank you
Steve Southerland
ssoutherland is offline   Reply With Quote
Old 10-05-2022, 10:01 PM   #2
TeddyK's Avatar
Boston , Ma
Following for links or sources of all AS electrical schematics
2005 25’ Safari Special Edition (International Package)
Sendel 16’s, Michelin Cross Climate, Shell on interior update (floor frame solid) Ampere Time lith batts, Victron Controls, Champion Dual Fuel 3400
WD Eaz-Lift 2 -1200lb bars 2-anti sway brakes
TeddyK is offline   Reply With Quote
Old 10-06-2022, 07:00 AM   #3
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Aren't they in your owners manual?
Richard
11018
richard5933 is online now   Reply With Quote
Old 10-06-2022, 07:36 AM   #4
LNBright's Avatar
2015 20' Flying Cloud
Kingsport , Tennessee
https://www.airstream.com/owners/man.../tt/year/2014/
-Leslie
WBCCI #1051
LNBright is offline   Reply With Quote
Old 10-06-2022, 09:04 AM   #5
OrangeCrush's Avatar
2017 25' Flying Cloud
Longmont , Colorado
The manual is not much value on this. All it says is "See 12V Schematic", which there is none.
In ours, the DC fuse panel has some cryptic labels that can be used to give you a rough idea on which circuit goes where. In addition, each circuit in the panel is color coded. If you think you shorted a wire then look at the color and see if you can identify it in the 12V panel. Worst case, take out one fuse at a time and check it with a meter as the LED indicators don't always work.
OrangeCrush is offline   Reply With Quote
Old 10-06-2022, 09:17 AM   #6
LNBright's Avatar
I just opened up the 2014 Sport manual (since that's what the OP asked about), and it has the schematics in the back.
-Leslie
WBCCI #1051
Old 10-06-2022, 12:02 PM   #7
Longmont , Colorado
Yes, I saw that. Unfortunately it is just like the other manuals I have seen and it only shows the AC circuit wiring schematic. There is no schematic or labels for the DC distribution.
Old 10-06-2022, 12:09 PM   #8
LNBright's Avatar
Isn't the first page the 12v diagram, then the second page the AC?
-Leslie
WBCCI #1051
Old 10-06-2022, 01:53 PM   #9
2018 27' Globetrotter
Columbus , Montana
Contact your dealer Service Desk. They should be able to email it to you. When I had an issue with my 2018 Globetrotter I spoke with my dealer and they were able to email it to me right away. Very helpful, but took some reading to understand it.
Ingstad is offline   Reply With Quote
Old 10-06-2022, 02:11 PM   #10
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Just pull the fuses one at a time till you find one that’s blown? Also there should be a label that lists what items use which fuse, along with the color of the wire. Though if you bought your trailer used, previous owner might have changed the converter out and possibly not put the wires back in the same order. Best bet is to just look at the fuses one at a time.
pcskier is offline   Reply With Quote
Old 10-06-2022, 04:35 PM   #11
Longmont , Colorado
Yes, but the 12V diagram only shows everything up to the DC distribution panel which is on the first page upper left. From there you have all the circuits with fuse and wire color but no indication on where they go.
Old 10-07-2022, 08:33 PM   #12
2021 25' Flying Cloud
Edgewater , Maryland
I called customer service at A/S mother ship and they PDF’d all of the electrical drawings (12, 120 (30 or 50 amp), coax, etc) for my 2021 25’ FC and emailed them too me.
Dr. Ohat is offline   Reply With Quote
1973 sovereign electrical diagram needed Al Falcon Batteries, Univolts, Converters & Inverters 1 06-25-2007 01:34 AM
'63 Electrical Wiring Diagram DenverAaron Electrical - Systems, Generators, Batteries & Solar 12 10-08-2006 10:32 AM
electrical diagram for a 1966 Ambassador 28 foot ups guy Electrical - Systems, Generators, Batteries & Solar 2 09-10-2004 05:24 PM
electrical system diagram duckrunner Electrical - Systems, Generators, Batteries & Solar 3 10-22-2003 08:53 PM
Electrical diagram 1958 Globetrotter Electrical - Systems, Generators, Batteries & Solar 5 10-01-2003 09:22 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
