RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-16-2020, 07:19 PM   #1
2016 19' Flying Cloud
Los Altos , California
100w or 200w solar suitcase
thinking of investing in a portal solar suitcase for our 19ft flying cloud. I've got AGM batteries and the Honda 2200 propane modified gen. but still would like to be able to top off batteries without running gen. Was thinking of getting the renogy 100w panel, but maybe the 200w one? Any thoughts on that?
Also, I know they come with alligator clips so I could just hookup directly to batteries, but wondering if anybody has modified the battery box by adding a quick plug-in capability. In other words, I would not have open the battery box and mess with Alligator clips..
jsmall01 is offline   Reply With Quote
Old 10-16-2020, 07:46 PM   #2
pjshier's Avatar
2017 27' International
Wasilla , Alaska
When it comes to solar capacity, I tend to over-do it, mostly because:
1. the cost difference is not that great
2. The weight is more but still very manageable, and
3. In less than ideal conditions, 200w panels in filtered or partial sun simply push more power than the 100w case.
We have a 200w Renogy suitcase and I am very happy with it. I use the clips for greatest effective reach, but the box is set up with the gopower connector, which must be reversed for the Renogy cable.
2017 Int'l Serenity 27FB
2017 F350 oil burner
pjshier is offline   Reply With Quote
Old 10-16-2020, 08:20 PM   #3
2016 19ft flying cloud
Spokane , Washington
I use an Echo worthy suitcase 120watt set up($235 on line)
I drilled a hole in the side of the battery box and added a female SAE plug that I picked up at the local auto parts store,,,make it an easy task to unhook at night and store away
Spinonedad is offline   Reply With Quote
Test of Renogy 100w Eclipse Suitcase w/Voyager Con blacklab Generators & Solar Power 13 07-26-2019 06:32 PM
Suitcase solar plug in to onboard solar. HankStarr Generators & Solar Power 10 06-12-2019 10:23 AM
review of the Harbor Freight 100W solar kit? Bob Blarney Electrical - Systems, Generators, Batteries & Solar 14 10-25-2017 02:15 PM
SOLD: 100W Flex Solar panel, Controller &amp: Display JayP Airstream Classifieds 0 07-04-2016 05:45 PM
