01-08-2021, 06:37 PM
2021 27' Flying Cloud
Austin
Securing AS and ProPride
Greetings all. Newbie here with a 27’ FC due to be delivered in early February. We can’t wait for our AS to get here!
After reading through a lot of threads about hitches and sway elimination, I decided to go with a ProPride.
The question I have for all you experts is do I need to secure the ProPride in any way in order to secure the AS while it’s stored at the outdoor (secured) storage facility?
Thanks!
01-08-2021, 06:41 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
ProPride hitches are such an anomaly that a “common thief” would not know what was needed or how to hook it up.
I thought about designing and building a locking plug for mine but after having it I do not feel it necessary.
01-08-2021, 06:46 PM
2013 30' Flying Cloud
Kingwood
Good insurance is your best thing to have. A determined thief will just wrap the safety chains around their bumper and take the trailer.
01-08-2021, 06:51 PM
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
Don't be misled the safety chains can very easily be wrapped around a tow hook and your Airstream is gone gone gone gone. My suggestion is to do what I do - remove the safety chains. This can be done using adjustable chain links. Then get two Trimax wheel chock locks for two of the wheels that way if it can't roll it can't be stolen. Also you can remove the fuse in the positive side to your jack.
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
01-08-2021, 06:54 PM
2002 19' Bambi
Lafayette
We have long used two combination padlocks to secure our Hensley hitch and the same method would work for a ProPride. With the stinger in the hitch and the over-center latches closed, one padlock goes through the safety pin hole for one of the over-center latches. We drilled out the hole in a long hitch pin to fit the second padlock. That hitch pin goes through the hitch-pin hole in the stinger and the padlock goes through the drilled out hole.
Are our simple padlocks truly theft deterrents? Probably not, but when our trailer is parked, the padlocks are in place in the hope that they will discourage easy theft. Makes us feel better and we would use the locks in a secure storage facility.
Tim
01-08-2021, 08:48 PM
2017 28' International
Jim Falls
, Wisconsin
Just take the stinger with you. If a thief comes with a stinger they are pretty determined.
01-08-2021, 09:23 PM
2017 30' International
Broomfield
Meh. Risk is so low and it they want it they’ll wrap chains and drag the it off. I don’t bother (plus my storage facility is well secured in a low risk area).
A boot would be the best defense of you are seriously concerned. It you really want to go crazy throw 4 boots on the thing with an obnoxious loud motion alarm!
01-09-2021, 05:13 AM
2006 25' Safari
St. Augustine
I do not worry about it. The facility should have some security and you should have insurance. My facility manager has moved my trailer quickly in spite of the pro pride hitch or lack of stinger. I am sure a thief could as well.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
01-09-2021, 07:30 AM
Austin
Thanks all for the info!
01-09-2021, 06:31 PM
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Welcome to the Airstream owner's community. I believe you will find these Forums fun and informative. I sure have over the years.
The Airstream is very secure here in Colorado. You just need a couple of feet of snow on the storage lot.
I have a pro-pride hitch and find it very good. No problems noted over the last 6 years. It is a bit of a hassle to leave the trailer at a service place as they have no good way to move it around. I have carefully dropped the pro pride off the coupler of the trailer so the shop can slide their lift truck fork between coupler and hitch and lift that way. I strapped the pro pride up so it wouldn't drag on the ground. Service manager was satisfied.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
01-09-2021, 07:26 PM
Austin
David
Thanks for your insight David.
I don’t think I’ll ever have that snow deterrent down here in Texas!
01-09-2021, 10:36 PM
Jim Falls
, Wisconsin
I would recommend that you get the ball hitch accessory to put on the Propride hitch. It allows the Airstream with the propride to be towed on a ball. Costs about $125. On their website. I carry it just in case.
