Old 07-07-2021, 09:58 AM   #1
1975 27' Overlander
Reno , Nevada
Ola based in Reno with a RENO :)
I just picked up a 1975 27 foot Overlander that needs extensive work. It has been fun reading all of the great information so far.
My biggest challenge is going to be axels as the frame has been modified and I dont have enough room between the upper shock mounts and the frame to remove the nut . The shock mounts are welded studs so I am thinking I have to grind off the welds and replace with bolts so I can get the nut between the bolt end and the frame
I also need to work on the opening mechanism for lifting the rear "door" if any one has any suggestions for a easier way to lift the door
scotinexcile is offline   Reply With Quote
Old 07-07-2021, 10:41 AM   #2
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver , Colorado
Welcome! You should definitely post a pic of the frame issue you are talking about so people can make suggestions. I have seen quite a few threads where people think something isn't possible, and they just didn't know the "secret."
With the hatch... what about mounting some kind of conduit or channel down the back on either side of the window that would contain cables mounted to a winch on the roof? Otherwise you'll need some kind of lift in the opening that will impede some of that wonderfully massive opening. Hydraulic and/or electric struts would be cool, but I assume cost prohibitive for something that large. It would be interesting to know how much force is needed to open the hatch (what does the hatch weigh?) You could also add counterweights on another set of cables and pulleys to "make the hatch lighter" like the counterweights in the wall/frame of old style house windows.
Either way, that's going to awesome once you get it working!
I can't really tell from the pic, but obviously you will also need to address the possibility of the structure back there shifting and deforming while traveling, and also getting a good seal when it's closed (I can't tell if the previous owner added additional ribs or other support structures).
kidjedi is offline   Reply With Quote
Old 07-07-2021, 03:52 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Oh, so many questions about that trailer of yours....
Anyway, post a pic of the upper shock bolt you are talking about. Even the factory set-up is crazy difficult to get a shock on and off without removing the axle. You might look at the outofdoorsmart.com site. They have some "how to" videos there, and they have one that shows the tricks to installing a new shock without removing the axle.
Also, there is at least one video on youtube.com showing an Airstream that has been modified to be a car hauler where the rear end opens up. As I recall, it was more of a side-hinge, rather than a top-hinge, but it might give you some inspiration.
good luck!
Old 07-07-2021, 04:15 PM   #4
1975 27' Overlander
Reno , Nevada
I will post some pics when I get back over to the trailer of the shock mounts.
The "door" weighs around 250 - 300 lbs (guessing) the previous owner had a electric motor mounted on the roof but it still needed two people to help lift it up. I am looking at some kind of screw jack system or hydraulics. The length of the "throw" is pretty long
I will post another thread with more detailed pics in the correct sub forum
Old 07-07-2021, 04:18 PM   #5
1975 27' Overlander
Reno , Nevada
good luck!
Thank you
I watched a couple of videos where the top shock mount was a bolt and not the welded studs. I am not sure when that changed or if one of the previous owners changed it
The rear has a dynometer for ATV's adn Motorcycles mounted in the back, which makes up all the weight
Old 07-07-2021, 07:42 PM   #6
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Welcome from Colorado: I too have a 75 Overlander that I did extensive work to, including new axles. I suspect your trailer is highly modified and has a completely different frame from the Airstream frame if you are hauling a horsepower measuring dyno around in your "garage".
Airstream shocks are hard to get on and off. I'll take a guess. What I might suggest is you remove the shock from the accessible lower bracket, and then lower the axle with the shock still attached to the upper bracket. That is what I do. The axles are heavy and awkward, but usually held up by two 5/8" bolts through the frame rails on each side. I have a floor jack under the balance point of each axle, lift enough to remove any bind on the bolts and then remove them, and carefully lower the axle to the pavement. Now the shock is easy to remove.
Photos of your situation would help us.
David
Name:	1907 Curb-800x600.JPG
ID:	399025   Click image for larger version
Name:	1905 Axle Front Mounted B-800x600.JPG
Name:	2003 Axle Lift Front-800x600.jpg
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 07-13-2021, 09:25 AM   #7
1975 27' Overlander
Reno , Nevada
I took a bunch of pictures on Saturday. Will get them uploaded and linked
city-based fulltiming? MeoHead1st Full-Timing 20 03-31-2008 10:23 AM
70's AS asphalt-based frame paint prep for POR-15 Wabbiteer Repairing/Replacing Floor &/or Frame 1 10-09-2006 08:23 AM
Site for Sprinter & Sprinter-based RV Enthusiasts Zach Woods Sprinter and B-van Forum 0 09-25-2006 04:08 AM
citrus based paint remover -anyone use it ? oldvws Cleaning, Stripping & Polishing 2 12-17-2002 10:45 PM
