Go Back   Airstream Forums > Airstream Community Forums > Our Community > Member Introductions
Old 07-16-2020, 08:52 AM   #1
1977 29' Ambassador
New Airstream owner and question about aluminum tanks
Hello all! We just bought a new old 1977 29' Ambassador. It needs a lot of work and has been in a storage lot for a couple years. Took the 2 aluminum propane tanks in to get recertified and filled. One was good, the other has a leaky valve. One of the propane guys told my husband, "don't let them talk you out of that tank. You can't find them like that anymore." Of course then the salesman tried to get my husband to swap for a new steel tank. Now we have this aluminum tank that needs a new valve. Over the phone, my propane store said they should be able to fix it, but I took it in and the guy said changing the valve was tricky because the aluminum would get stripped and it would be no good. I haven't come across this issue in the forum questions I've looked through, only that the dip stick is different between steel and aluminum tanks and that's the problem with getting the valves replaced. Was this guy just trying to scam me, or is this a real problem? Or, should I just buy the right valve and figure out how to change it myself? Thanks!
WORCShopATX is offline   Reply With Quote
Old 07-16-2020, 09:05 AM   #2
Central , Mississippi
It’s probably a Worthington tank, they still make them. I guess it’s possible that the tanks threads will strip but I’ve never had that problem with the 4 tanks I’ve re-valved.
I do recall that finding the right valve took some research since my aluminum tanks were different dimensions than the same capacity steel ones.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 07-16-2020, 09:08 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Scam. Keep the aluminum. The valve both need replacement to new OPD. You can buy at LP distributors or last chance amazone. They are standard.
Run all the propane out. Vent to atmosphere. I had ours changed in Cedar Park.
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-16-2020, 09:24 AM   #4
"Cloudsplitter"
What I did...
Get a heat gun...the sealer used on the threads will get soft with heat, strap the tank to a tree with a ratchet strap, find a spanner that will fit the valve, use a breaker bar to work the valve back & forth, remove valve, let the LP evaporate in an open outdoor space & use the old valve to match with the new valve.
Have the tanked purged & filled.👍
KEEP those tanks.
Old 07-16-2020, 10:41 AM   #5
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver , Colorado
Heat gun (or even just a hair dryer on high) to loosen the valve is good advice.
If someone is telling you that the valve is too hard to replace, they're just trying to sell you something (literally).
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
kidjedi is offline   Reply With Quote
Old 07-16-2020, 12:55 PM   #6
1977 29' Ambassador
OK, so my propane guy is giving me a load of horse manure. I'm guessing I should change it myself. Now to find the right OPD valve for my 30 lb aluminum tank. There was a link to one I found on this forum at Out-Of-Doors Mart, but it said it was stamped with 5.8 for the dip tube on the side and my tank says 6.0. I called the place and they said I should find one that fits my tank. They only have that one. I called an rv place here in Austin and they can do it all tolled for just under $100.... Hmmm, if I can't find the $30 part myself, I guess I go there and pay way more. Sigh.
Old 07-16-2020, 01:19 PM   #7
kidjedi's Avatar
1972 25' Tradewind
1975 24' Argosy 24
Denver , Colorado
I assume "all in" includes certification? Maybe try and get them to throw in a tank fill as well, and it will be worth just having it all done (and re-certified).
BeahmStream.com
Old 07-16-2020, 02:33 PM   #8
Soready's Avatar
2020 30' Classic
Mitchell , South Dakota
We had an Argosy some years ago that had aluminium tanks. When we sold it I did keep the aluminum tanks. We use them for grilling and ice fishing, anyway, they had the old valves that had to be replaced with the newer OPD valves and re-certified before our local propane company would refill them. They informed me of the same risk, the threads can sometimes be damaged beyond repair but they would try. It went fine, new valves and re-certified. I think they just want to make sure you know the risk on expensive aluminium tanks.
2020 Classic 30 RBQ
2019 GMC Sierra 2500HD Denali
Hensley Arrow
Soready is offline   Reply With Quote
Tanks, Tanks, Tanks PSU1981 Plumbing - Systems & Fixtures 8 09-02-2019 09:34 AM
Twin Aluminum LP Tanks, Carrier, and Hookup bryantclaire Airstream Classifieds 0 07-25-2017 06:39 PM
Swirl O Matic and BIG aluminum propane tanks Globestream Our Community 3 11-15-2011 11:17 AM
old aluminum and new aluminum hill4th@gvtc Ribs, Skins & Rivets 6 08-03-2006 07:00 PM
where to buy new aluminum lp tanks.. JohnGalt48 LP Gas, Piping, Tanks & Regulators 3 09-14-2002 10:36 PM
