Old 02-24-2021, 12:54 PM   #1
2019 25' International
Lincoln , Nebraska
Lithium batteries
Hello all, I've been a member of this forum for quite a while, but I tried to private message CMHM thanking him for his information on lithium batteries and asking a couple questions. The forum says I can't private message until I'm a trusted member of the forum. It said to introduce myself, so here goes.
We have a 2019 International Signature 25FB. I'm wanting to upgrade to lithium batteries. We do not have solar. CMHM had some great information.
My questions are: Should heavier cables be installed between the new converter and the batteries? Someone mentioned protecting the alternator in the tow vehicle. Can someone explain that to me?
Thank you very much.
Gordon Opp Lincoln, NE 402-617-1129. gordon.opp@woodsbros.com
gordonopp is offline   Reply With Quote
Old 02-24-2021, 01:25 PM   #2
LNBright's Avatar
2015 20' Flying Cloud
Kingsport , Tennessee
Just to touch on the tow vehicle issue: https://amsolar.com/rv-battery-accessories/98-altclitow
-Leslie
LNBright is offline   Reply With Quote
Old 02-24-2021, 01:51 PM   #3
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Hi Gordon,
Here is a video from the series, Ask an Airstreamer. I found it informative and you might as well.
https://www.airstream.com/ask-an-air...power-systems/
BTW I visited a supplier we had in Lincoln often in my working days. Nice city (except in winter then not as nice)!
Old 02-24-2021, 11:16 PM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Lithium batteries
No you do not need to change cables if all you are doing is dropping in new batteries and a new converter.
Regarding your tow vehicle, you will need to simply pull the 30A fuse for the trailer 7-way plug 12v constant charge line. This fuse is located under your hood in the engine bay or in your glovebox or what have you. Check your manual.
Why? Lithium’s have higher voltage than the lead acid battery in your tow vehicle. You will actually reverse current and drain your lithium’s if you leave them connected to the tow vehicle without the engine running. Plus your alternator does not put out the correct voltage to charge lithium when it is running. There is a list of other issues but those are the main ones.
That is the simplest and most economical approach (pull the fuse). If you want to charge your batteries from the tow vehicle then you need to add a DC-DC converter to the system.
wulfraat is offline   Reply With Quote
Old 02-25-2021, 03:17 AM   #5
Long Island , New York
Welcome to the forum, Gordon.
FYI these "add lithium batteries" search results should lead to some helpful threads/posts IMO:
https://www.google.com/search?q=add+...=airforums.com
Also the Electric etc. forum, and its Batteries etc. sub-forum would be good places to look for information:
https://www.airforums.com/forums/f37/
https://www.airforums.com/forums/f449/
Good luck.
FYI
FWIW
Let the music lift you up . . .
Have a little pun in life . . .
Peter
Old 02-25-2021, 05:06 AM   #6
Ch47d1sg's Avatar
2019 30' Flying Cloud
Trophy Club , Texas
Following ��
Top
2019 Flying Cloud 30 RBT Flying Warrior
2016 Silverado Z71 Heavy Half, 6.2l max tow package and Hensley Arrow hitch
“Tomorrow is not promised”
Ch47d1sg is offline   Reply With Quote
Old 02-25-2021, 09:20 AM   #7
2018 30' Flying Cloud
Anchorage , Alaska
There is a jumper in the Airstream’s DC panel that ties in the charge line from the vehicle. In mine it goes to CB3. Removing that jumper is a better idea than removing the fuse in your TV, IMO. That way your trailer will be fine with any TV and your TV will still be fine for any trailer.
If the OP doesn’t have solar though, it’d probably be a good idea to just add the DC/DC converter so they can charge while towing.
AKNate is offline   Reply With Quote
Old 02-25-2021, 12:14 PM   #8
Mollysdad's Avatar
I just watched a LoLoHo video where they upgraded the alternator in their Tow vehicle after adding Lithium batteries and solar.
Changing from lead acid to Lithium batteries is more of a process than a battery swap.
Old 02-25-2021, 09:00 PM   #9
2021 27' Globetrotter
Malibu , California
Hi Gordon,
Sorry you couldn't direct message me, but I am as new to this as you are. The PDF I attached to the other post is basically what is given to Airstream dealerships for the upgrade.
The part with the tow vehicle is new to me, and seems very important. Could anyone explain what happens if the fuse is not taken out?
CMHM is offline   Reply With Quote
Old 02-25-2021, 09:07 PM   #10
wulfraat's Avatar
See post #4 above
Lithium Batteries? galvestongrl Sprinter and B-van Forum 76 10-03-2018 05:23 AM
Upgraded My Batteries to Lithium - Woo Hoo! burnsdl Electrical - Systems, Generators, Batteries & Solar 21 12-02-2015 09:43 AM
Lithium Iron Phosphate Batteries GenXair Batteries, Univolts, Converters & Inverters 39 06-06-2015 08:59 AM
Lithium Batteries for Solar ghaynes755 Generators & Solar Power 26 01-13-2015 09:02 AM
Electrical, Solar, Lithium Batteries on 28' International wbrown Electrical - Systems, Generators, Batteries & Solar 25 09-13-2014 06:44 PM
