Old 06-17-2021, 06:11 PM   #1
2021 23' Globetrotter
Howdy and water pump died help with
Just joined site. Owned 2021 16rb caravel sold and now just got my new 2021 23fbq.
Out on maiden voyage and water pump just stopped working on my way from Austin to Asheville ? Pump working fine was on battery and inverter. Turned off pump and at next stop turned on pump and no green light and no pump. Checked fuse
agriffis1 is offline   Reply With Quote
Old 06-17-2021, 06:39 PM   #2
2018 19' Flying Cloud
Newport , Washington
Is your Store/Use switch in the Use position
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
KelloggKid is offline   Reply With Quote
Old 06-18-2021, 08:32 AM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Maybe you are one of the very few lucky people experiencing an "infant failure" of a significant component. I would verify you are delivering 12v to the pump. If the switch is in "store" the system won't deliver 12v to the pump. If you verify you are delivering 12v to the pump, then stop by the most convenient Airstream dealer and make a warranty claim. They should take care of you right away.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 06-18-2021, 10:19 AM   #4
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Depending on your route and how far along you are:
Don't bother with the AS dealer in Tennessee. Head over to Out of Doors Mart in North Carolina. (at least that's been my experience).
If you aren't that far along then ... never mind .
The water pump runs on 12V. The inverter being on or off should have no impact on it. It has a fuse or breaker that might have blown. That would be unusual. It also has wires attached with crimps / wire nuts. Having an early failure there ( wire nut falls off) is not at all unusual.
Good Luck !!!
Old 06-18-2021, 06:18 PM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Uncle Bob is right on Out of Doors Mart, even being a half a rivet short. They run their business quite well in my experiences with them.
David
Old 06-20-2021, 08:18 AM   #6
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Can you post a pic of the pump and the two electric wires?
Do you have a DC test light or multimeter?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 06-21-2021, 07:05 AM   #7
Yup. We were were in a 1170 mi treck. Made two stops no issue after second stopped turned off water pump from panel with tank levels, did not touch batt disconnect as have fridges going and have 4 x 100 ah lithium and 3k inverter so no worries about batt life. Third stop went to turn pump on and no green light and no pump.
Old 06-21-2021, 07:08 AM   #8
Sag Harbor , New York
Welcome to the forum. You might also want to check in the sub-forum which includes pumps for relevant threads/posts IMO:
https://www.airforums.com/forums/f445/
Good luck,
Peter
Let the music lift you up . . .
[Robert Frost reading live -- 2 minutes]
1987 325 MH died on the road....help! realpank Classic Motorhomes 78 08-25-2021 09:42 AM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Help! My microwave died dgray Stoves, Ovens & Microwaves 6 03-30-2013 06:11 PM
12 Volt System died....Need help! Tikiman Electrical - Systems, Generators, Batteries & Solar 3 11-28-2005 04:32 AM
Help and advise she died in the middle of nowhere saxonsraven Airstream Motorhome Forums 7 07-29-2003 07:10 AM
