Old 12-06-2015, 06:39 PM   #1
2016 23' International
Bastrop , Texas
Exclamation Help please 2016 Grand Tour with No AC/Heat
I am leaving for Virginia for the Holidays and have no climate control. I have check the 20 amp breaker and fuse 5 and both appear sound. I have no response at the Dometic thermostat. Nothing! I have hooked to shore power and turned on the generator. Neither give me any response at the thermostat. No light...nothing. I turned off all power to the coach hoping for a reset. Again, nothing. Any ideas from the experts out there?
Airstream42 is offline   Reply With Quote
Old 12-06-2015, 08:25 PM   #2
Andrew T's Avatar
2019 27' Tommy Bahama
London , Ontario
This is pretty obvious but you do have the 12 volt kill switch on? The control system needs 12 volt to operate, if you have inside lights then it has power.
You should have enough engine heat while you are driving.
Call Airstream first thing in the morning and they may be able to find you a service centre along the way. If the service centre can't fix the Dometic unit they can put a standard 2 wire thermostat on the two blue wires coming out the furnace.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 12-06-2015, 08:27 PM   #3
Andrew T's Avatar
London , Ontario
There will be a 15 or 20 amp fuse in the main panel that powers the AC control and furnace. Again obvious but I thought I would mention it.
Andrew T
Andrew Thomson
London, Ontario
2016 Interstate Grand Tour - Better solution for front night shades? Tao Sprinter and B-van Forum 25 10-01-2016 09:56 PM
2016 Grand Tour steering vibration Sgkh1947 Sprinter and B-van Forum 13 11-18-2015 07:53 PM
2016 Grand Tour battery problem Bobsprinter Sprinter and B-van Forum 12 08-13-2015 04:46 PM
Drivers seat - extended? 2016 Grand Tour Tao Sprinter and B-van Forum 17 07-04-2015 10:35 AM
