Hi and welcome from the middle of Colorado: Globetrotter is a very old and classic Airstream model name. The new Globetrotters are nothing like the old ones, the new ones are much better in my view.
My son and I renovated his 69 Globetrotter 21' last winter. He has owned it for 12 years but doesn't use it much. It was in reasonable shape, but it had many needs. We installed new tires, a new axle assembly, a new belly pan, new under floor insulation, a new and larger waste water tank, repaired the subfloor, new floor covering, new plumbing, cleaned and painted the interior walls, built new cabinets throughout, installed a new fridge, new galley stove and sink, and built a new mid bath, new light fixtures, and a new roof vent. I probably forgot some items. Here are some photos as I figure you would be interested. Like Bubba L says, if I can do it, so can you.
1969 is the first year of the new body style. I found the Globetrotter very well built with good cabinetry and the like. Go to the knowledge base at the bottom of the Forums page and select Globetrotter, and then 1969. There you can see what we did, and see many other project threads.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
