08-17-2019, 01:50 PM
#41
2020 25' Globetrotter
Santa Rosa
Originally Posted by Mollysdad
Yes.
The reason being the toilet is behind the axles, while the black tank is in front of the axles. So, I know I've belabored this, but a look at the plumbing diagram shows the toilet drain has to go up and over the wheel wells.
Think of it as an airplane toilet with a smaller opening.
If Airstream flipped the bathroom, then the shower would have to be pumped over, that doesn't work.
The fresh water tank is between the axles, while the grey and black are in front. If they put the black tank under the toilet then you'd need two sewer hoses.
I think they made the right choice.
It does me, because I make use of other bathrooms! My black tank is all fluid.
Someday, I'm sure I'll be faced with "Feet, don't fail me now!" and I'll give it a real test.
Seriously, the toilet, if used normally should not extend the range. It doesn't burn, bury, or compact the solids, just moves them around.
Thanks!
Mike
2020 25' Globetrotter Twin | 2024 GMC Sierra 2500HD Denali Ult. 4x4 Duramax
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
08-17-2019, 02:04 PM
#42
Trailer Sold, Waving
2019 26' Flying Cloud
Stettler
, Alberta
Originally Posted by Too tall
What is your favorite thing about the layout?
The bathroom. Might be my imagination, but I feel the shower is just a bit bigger than all of them except the Classics. And a tip - I use the bathroom door as an indicator of level fore and aft. After getting parked and leveled with my iPhone measuring tool, the swing of the open door acts as a good fore-aft level indicator. I also like the huge slide-out pantry. And 50 amp + two AC units really comes in handy on a hot day.
Tip for 26RBQ owners. The bottom false front under the bedroom two corner cabinet drawers comes off, and reveals a nice hidey-hole over the right wheel well. Just gently pull it using any dull-edge tool - putty knife, spoon, whatever.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
08-18-2019, 04:36 AM
#43
Kensington
, Maryland
Acheron, now I know where to hide the chocolate
Dave - Hot water eh? That's a good tip. Why balance the tanks? Is that for towing stability?
08-18-2019, 12:08 PM
#44
Kensington
, Maryland
For the record, found some answers wrt towing etc.
2017 Tundra (ours) max combined occupants + cargo = 1295 (from the door sticker)
2017 Tundra max tongue weight = 1,020
2019 FC RBT Hitch weight = 903
08-19-2019, 03:45 AM
#45
Moss Point
, Mississippi
Just to balance the volume. Both tanks are 39gal, grey fills much quicker than black.
08-30-2019, 03:31 PM
#46
Going to pick up our new 2019 26RBT Tuesday. Wife and I are pretty excited! TV is a 2017 F250 6.2 CCSB.
08-30-2019, 04:17 PM
#47
Moss Point
, Mississippi
Nice!! Hope you enjoy it and your TV! Pretty much same setup we have.
08-31-2019, 04:46 AM
#48
Kensington
, Maryland
Thanks again to Chris the hitch whisperer at Colonial Airstream, NJ for stellar work setting up the Equalizer Hitch for our new 26 RBT / Tundra combo. I just finished two tows for a total of 800 miles and it's fant-tastic.
FWIIW We are 110% loving the 26 RBT configuration. We have the Microwave/Convection which gives a huge pantry option.
