Busy, busy weekend! We got a great deal of the interior removed. David, thank you for your advice, I will post this in the classifieds but I have a stove/oven, heater and kitchen counter/cabinet that I took out, all free to a good home, shipping would be $$ because it is all HEAVY but if you are close it is all yours! I have a picture of the stove included, the interior looks almost brand new, impressive for a 62!
It poured down rain most of the day while I was in there and surprisingly I found no water coming in the windows so at least ONE thing isn't leaking but based on the severe floor rot and frame rust in the front it is coming in somewhere.
I have pictures attached but the previous owner had a table opposite the kitchen which they both screwed and GLUED to the wall, like some serious glue, we are not talking Elmers craft glue here. I used a sturdy paint scraper and a hammer to break it free with little to no damage to the internal skin, now I just have to get all the glue residue off. I am going to try a few solvents to see what works but I am open to any suggestions.
The PO was fond of glue I have found as well as finish nails, they actually shot finish nails into the interior skins to attach wood blocking under the kitchen cabinet.
I got the kitchen cabinet out as well which included the giant heavy heater and found one major leak source which was the heater vent, you can see where water has been running down the wall staining the aluminum and pooling underneath.
I cut into the closet wall to get it out easier without damaging the curve so that I could use it as a template and was surprised to find it was made of cedar and was still very aromatic!
As pictures show I found lots of floor rot up front, all the way thru in fact, some looking at air others bellypan. Also found a metal for sale sign used as a patch, very nice!
You will also note that the front cross member on the tongue was hidden behind a piece of metal and when I pulled it back I discovered it was 100% rusted out, really afraid of what we will find moving forward but I already have someone lined up to handle frame repair, just hope I do not find anything that cannot be repaired.
Today is the rear of the GT's turn, bathroom, tub, hot water heater, black and grey tanks....it all has to go!!! Too wet to get underneath it today and mess with belly pan and I think the bathroom will eat up the time I have to give today anyway but we are making progress. I ordered about $800 worth of stuff from Vintage Trailer Supply, Airstream, Out of Doors Mart and ATS that should be arriving in the next day or two so that is exciting. I found different sites offered better prices on different items.
Got a quote on the Axle from Inland RV, $1253, but that is for the Axle, shocks, balancers, install kit and shipping, here it is:
0607 Complete axle 3.5k rating, 12" S.A elec brakes, 6 on 5.5$845.00
Airstream Axle Shock$85.00
($42.50 ea.) × 2
Airstream Axle Shock for Dexter torsion axles. OEM Airstream Axle Shock compatable with all Airstream trailers. This proprietary shock is made specifically for Airstream Trailers by Gabriel. Airstream axle shocks can be installed horizontally or vertically with torsion axles. Airstream converted from a vertical bracket in the late 60's to a horizontal bracket orientation which requires some trailers built from
1968 and down to modify the shock bracket location on the chassis. Dampering Distance: 9.38" - 14.46"
30050 Axle hardware kit$10.00
Airstream Axle Shock Bracket Set$84.00
Airstream Axle Shock Bracket Set (Left & right) and includes a pre-welded shock stud. These brackets are machined from steel to be welded directly onto your Axle Torsion arm. Welding directly to the torsion arm does not harm the interior working of your torsion axle. See more about how to install shock brackets here. Part# 12400 & 12410
13150 centrmatic wheel balancer$137.90
($68.95 ea.) × 2
Freight- commercial address$175.00
Discount-$84.00
Subtotal$1,252.90
Anywho, I will keep updating for anyone interested!
Nick
