03-07-2022, 12:55 PM
1993 29' Excella
LANGLEY
, BC
Airstreamer
Hello from the great white north, looking to learn how to convert my rear queen bed to twins, then hit the road, 93 Excella 29'
Cheers
Brian
03-09-2022, 07:01 PM
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Hello from Colorado: The Excella name has been around since the early 1970s. You have a nice Airstream. I'm with you, twins make more sense as they are easier to make up and the like. We have a 86 Limited 34' with rear twin beds.
So I would start by sketching your design for the rear twins. Then removing the existing furniture carefully. It will come out the entry door. Now built the new twin bed framework. Airstream uses plywood as a mattress support, and the plywood lifts up to access under bed storage. You can order foam on line and cut it to fit the curvatures of the rear of the trailer. I like to have the headboards and reading light toward the bulkhead walls where the mattresses are wider, and my feet toward the rear window where the mattresses are narrower. Here is a photo of the Limited rear twins with no mattresses.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
03-10-2022, 04:07 AM
2020 23' Flying Cloud
2019 22' Sport
Sebastian
Brian,
Good luck with your conversion, and many happy travels to you!
Someday we are gonna make it back up there.
-Don
(That man in that tiny can)
(Same man, Bigger can)
03-10-2022, 08:42 AM
1993 29' Excella
LANGLEY
, BC
Hi David
Thx for the info and the pic, thats exactly want I'm going for, looks great, did you use 1/2, 5/8, or 3/4 plywood?
Cheers
03-10-2022, 10:50 AM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
Voila
Originally Posted by Excella29
... looking to learn how to convert my rear queen bed to twins, Cheers
Brian, welcome to the site! Look for the "Search" selection in the blue bar above. Enter whatever 'terms' describe what you want to find and your reveal will follow. A sample:
https://www.google.com/search?q=quee...=airforums.com
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
03-10-2022, 06:49 PM
1986 34' Limited
1975 27' Overlander
Conifer
I use 1/2" sanded both sides plywood for the mattress support. I applied polyurathane to both side of the plywood. There are "slats" to support the plywood about every 3' under the plywood. These are hinged so the bed can be lifted and gain access to under the bed storage. There is a prop rod to hold the bed up. I used 3/4x1 1/2 red oak dimensional wood for slats as it is very strong. I made my twins bigger like 32" wide instead of the Airstream 28" wide. The photo is the twin beds I made for my Overlander. It is a twin bed, rear bath layout. Completely different than your Excella.
David
03-11-2022, 08:57 AM
1993 29' Excella
LANGLEY
, BC
Well thats a great staring point, thx for the info! If your in my area pop over for a beer!
Cheers
Brian
03-11-2022, 06:09 PM
1986 34' Limited
1975 27' Overlander
Conifer
You're most welcome. These Forums have helped me in so many ways over the last 10 years. I enjoy working on these old, dirty, smelly, rusty, broken Airstreams and making them comfortable and reliable travel trailers again. And I like making them suit our needs. You want rear twin beds, you can build them.
David
