Old 09-25-2021, 01:08 PM   #1
2007 31' Classic
Gulf Breeze , Florida
Wirecon receptacle
In the process of tracing a short in my house wiring I damaged one of the self contained Wirecon receptacles in the aluminum wall of the Airstream. The tool for pressing the termination wires into this outlet is about $80.00 and I don’t want to buy one for a single shot repair. I do need the locking mechanism used to install the receptacle. It is similar to an “old work” remodel outlet box.
So I am looking for a Wirecon type receptacle that uses either a push connection, or termination screws. Anyone out there encountered this and found a solution.
https://hubbellcdn.com/ohwassets/HCI...ure.pdf#page=3
trumpetguy is offline   Reply With Quote
Old 09-27-2021, 10:35 AM   #2
2007 31' Classic
So I was able to repair the short. The Romex outer sheath plus a bit of the black wire was torn and the black wire was touching the ground. This must have been done during production because the yellow sheath had a large rip..as if it were yanked hard and hung up on something.
I still need to replace the receptacle so any ideas will be appreciated.
Old 09-27-2021, 11:12 AM   #3
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
If you want it done right, get the correct tool for the job.
Hubble Wirecon Tamper-Resistant SCD dave_oleary Electrical - Systems, Generators, Batteries & Solar 4 03-10-2014 08:57 AM
Electrical Help - Splitting a receptacle COArgosy78 Electrical - Systems, Generators, Batteries & Solar 4 07-03-2005 03:57 PM
Antenna/TV receptacle Al1 All Argosy Trailers 11 07-06-2004 12:20 PM
Electrical receptacle in storage compartment Kistler Our Community 4 06-27-2003 07:18 PM
receptacle replacement 1960 overlander rod Electrical - Systems, Generators, Batteries & Solar 3 10-31-2002 07:19 AM
