Old 03-14-2018, 10:55 AM   #1
2006 31' Classic
Youngsville , Louisiana
Water Pump Replacement
Our water pump in our new to us 2006 Classic 31' is leaking. looks like the gaskets. we are going to replace it completely.
Can someone suggest a good, quiet replacement?
TIA
Lynn
Barnbridge is offline   Reply With Quote
Old 03-14-2018, 11:25 AM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Shur Flo revolution.
Inexpensive, quiet, usually a direct fit replacement.
Old 03-14-2018, 11:38 AM   #3
Long Island , New York
Welcome to the forum Lynn!
FYI the new search function above in the blue box works great -- powered by Google to search this entire site -- "water pump quiet" results:
https://www.google.com/search?q=wate...=airforums.com
The "Water . . . Heaters" sub-forum also contains a list of topics which may help:
http://www.airforums.com/forums/f445/
Good luck,
Peter
OTRA15 is online now   Reply With Quote
Old 03-16-2018, 01:42 PM   #4
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I replaced my Aguajet with the Shurflo Revolution 4008. I also added the Shurflo accumulator. The accumulator allows you to run a faucet at a trickle and not get pulsing water. When I installed them together and presurrized the first time the pump wouldn't stop running. I removed the accumulator temporarily and the water pump pressurized the stopped. When I connected the accumulator again the pump stop when reaching pressure. I was able to use the existing inline filter and the PEX screw on connector to the input side of the Shurflo. I purchased a couple of 90 deg connections to route the flexible hoses to/from the accumulator. I like this water pump so much I don't connect to water hookups any more, I just fill the water tank and use the pump.
Kelvin
Old 03-16-2018, 03:42 PM   #5
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
I have the shurflo revolution. I was lead to believe it doesn't need the accumulator tank, but I found that it performed much better after adding the tank. I didn't like all the pulsing and the vibration from the faucet, and the tank basically eliminated that. The "water pump silencing kit" consisting of flexible hoses to bridge the space between the pump and the plumbing is worthwhile to dampen the noise.
TheGreatleys is offline   Reply With Quote
Old 03-16-2018, 06:35 PM   #6
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
I don't know what quiet is as I have this pump but have never compared it to another, so I don't know.
http://www.campingworld.com/aquajet-...er-pump-53-gpm
Cheers
Sidekick Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 03-20-2018, 03:09 PM   #7
2006 31' Classic
Thanks Everyone.
looks like the Revolution is the way to go. Anyone know a model number. and specs, like psi and gpms?
Old 03-20-2018, 03:42 PM   #8
RxGuy's Avatar
2010 27' FB International
Bois Blanc Island , Michigan
I just bought the Shurflo 4048 High Flow water pump. The 4008 is 3 gpm at 55 psi, the 4048 High Flow is 4 gpm at 55 psi.
http://www.campingworld.com/shurflo-...low-water-pump
The 4048 was a direct replacement for the Shurflo 4900-0201 (it was 4 gpm) that was in my trailer. Thats why I chose the high flow.
Hope this helps.
RxGuy is offline   Reply With Quote
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Pump in RV Antifreeze Downstream from the Water Pump? KJRitchie Winterizing, Storage, Carports & Covers 6 01-09-2015 01:18 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
