Old 01-07-2018, 11:51 AM   #1
Whitney , Texas
Water pump
After 4 month storage, I brought AS home to ready for trip. After filling my fresh water tank I turned on water pump to flush air out of the lines. After having water flowing from all faucets and flushing toilet, I notice when all faucets are closed the pump continuously cycles on and off. Real low and slow, then shuts off for about 10-15 seconds then starts over again. I have checked for leaks and have found none. Iím thinking new pump, pressure switch? Where is the pressure switch located?
I have a 2008 Classic 30í, water pump is below clothes closet..
goldwing1 is offline   Reply With Quote
Old 01-07-2018, 12:13 PM   #2
2002 19' Bambi
Lafayette , California
There could be small leak somewhere in your plumbing system. I hope not.
We had the same thing happen with a high-end water pump shortly after installing it a number of years ago. Turned out it was an internal problem in the pump. Replaced that one with another that stopped working at all within a day. Another high-end pump from another manufacturer had no problems and has worked perfectly ever since. A great relief, because we could stop worrying about a leak.
Tim
Tim A. is online now   Reply With Quote
Old 01-07-2018, 12:37 PM   #3
Whitney , Texas
Thanks Tim, we are departing for Quartzsite this coming Wednesday, I do not have time to deal with it before we head out. I have checked all water lines, fittings, and drain lines and all is dry as fare as I can tell. I will use city water hookup until I get a chance to address it when we get to Quartzsite . I have never been there before but I understand if what you need is not there then itís not as yet made for the RV.. Iím sure there will be a rep there to consult with, at least I hope so.
Old 01-07-2018, 12:52 PM   #4
Long Island , New York
Do you have access to city water? I would hook up, turn water on for an hour or so, and then see if any water is dripping from the AS. Any leaks should reveal themselves in this hour.
Then open up the pump compartment, turn it on for an hour, and look for pump-related leaks.
If no leaks, sounds like a new pump is in order. At least you can turn the pump on and off manually during your trip. Don't leave it on at night, which is what we usually do anyway. Also, always leave pump off while towing.
Have a great trip!
Peter
OTRA15 is online now   Reply With Quote
Old 01-07-2018, 01:04 PM   #5
Whitney , Texas
Thanks got your input, we always turn pump off when not in use plus we turn off city water when we are not in coach.. I will check for leaks after we get hooked to City Water.
Old 01-07-2018, 01:19 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
One other possibility:
The suction hose between the pump and the FW tank might have a loose fitting, like the threaded connections at the filter and pump, that can be tightened. This could allow air in or out of the pipe. If the air leak is small enough the pump could over come it, it will draw water out of the tank. But this small could also allow air in so that the pump looses its prime when water drains back into the tank, causing the pump to cycle.
Alan
A W Warn is online now   Reply With Quote
Old 01-07-2018, 01:24 PM   #7
Whitney , Texas
Thanks, I will check that..
Old 01-07-2018, 04:25 PM   #8
STREMN's Avatar
2008 30' Classic S/O
Hampton Beach , New Hampshire
Try the easy stuff first...
Hi - Had a similar issue with ours. Turned out to just be some air that wasn't purged after filling.
Had the FW tank full, ran the pump, purged the fixtures and things seemed ok, but it wasn't. I connected to the CW put pressure to the system and purged the fixtures again. No more issues when we disconnected and ran totally off the internal system. Must've been air trapped in a mystery pocket somewhere.
Just my 2 cents, YMMV.
Best wishes for a quick fix!
Tom - S/OS #025
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
STREMN is offline   Reply With Quote
Old 08-27-2018, 09:22 PM   #9
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Sounds like the city water pressure cleaned out your pressure switch or check valve. That was a good idea.
guskmg
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Pump in RV Antifreeze Downstream from the Water Pump? KJRitchie Winterizing, Storage, Carports & Covers 6 01-09-2015 01:18 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
