Old 06-15-2017, 06:32 AM   #121
Slide out society #002
Nogginsbro's Avatar
2003 30' Classic S/O
Newnan , Georgia
Originally Posted by GCinSC2 View Post
I was about to mention that makes two with the smoke rock guards. We need a side by side shot of those rigs.
Soy,
You're actually S/OS #31
I thought Mike28 was #31? I would like to camp next to Soy for a photo shoot! Sounds like a road trip.
2003 30' Classic Limited S/O
2015 F350 diesel 4X4
Amateur radio call KB4GFN
Nogginsbro is offline   Reply With Quote
Old 06-15-2017, 06:47 AM   #122
mike28's Avatar
2005 28' Safari S/O
Lakeland , Florida
Keeping 31!
I am from Florida, but not a OJ fan...you are #32!
mike28 is offline   Reply With Quote
Old 06-15-2017, 06:55 AM   #123
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Ok I need to use a pc not phone.
032 is correct. I apologize.
GCinSC2 is offline   Reply With Quote
Old 06-15-2017, 06:45 PM   #124
Nogginsbro's Avatar
Newnan , Georgia
Sure hope we don't have to cut your pay! Haha.
Old 06-16-2017, 12:47 PM   #125
GCinSC2's Avatar
A pay cut means I'll have to cut back on my coffee pot collecting.
Old 06-16-2017, 08:40 PM   #126
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
SO/S #15 has been been carried by Marathon's ST and Maxxis ST tires in its life. Both brands of tires have failed with belt separations. I went to 16" Michelin's in July of 2012. So far the Michelin's have passed the service life of either of the ST brands. Personally I don't believe the ST tires are reliable once you hit 3 years of service if you are using them on a tandem axle slide out. The Marathon's failed at the end of their 3rd year of service and the Maxxis' started separating at the beginning of year 4 of service. I figured the cost benefit of either replacing the ST tires during year 3 of use or going with the Michelin 16" LT's. Ends up it's cheaper if you can get 5-6 years of service with the Michelin's.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 06-16-2017, 11:18 PM   #127
1969 31' Sovereign
1982 28' Airstream 280
Edmonton , Alberta
I skimmed through really quick. So there are 84 approx only with slides? I know of one in St. Albert, Alberta Canada is this member on here? It's a triple axle I forget which year it is I asked several years ago really nice people.
Swillv8 is offline   Reply With Quote
Old 06-17-2017, 05:21 AM   #128
2007 34' Classic S/O
Hillsboro , Texas
Trailer tires
From SOS #13: One thing to keep in mind if you decide to run truck tires on your Airstream instead of ST trailer tires, there is less sidewall flex on a truck tire than an ST tire. This translates to more lateral stress on your wheel bearings. If your trailer has Dexter axles with NEVR-LUBE hubs and bearings, you can't inspect these for excessive wear like the regular, non-sealed wheel bearings. It is important to have a qualified service shop measure the bearing "run out" which measures the lateral play that the hub has on the axle stub where the wheel is mounted. I don't have any data on how much is too much run out, but it should be available from Dexter. My shop owner measured the run out on my triple axle trailer and said it was not excessive. A triple axle trailer tends to pivot on the center axle when turning and lateral stress in opposite directions occurs on the front and back axles. This is just something you should be aware of and have checked periodically. The new Goodyear Endurance trailer tire is made in the USA and available in a load range E. Trouble is that they aren't currently available in a 225 75R16 to fit my trailer. Maybe next year.
John Green, Hillsboro, TX
2007 34' Classic LTD S/O
2011 Dodge RAM 3500/Cummins power
WBCCI #4432 & ARC member W9CJX
jwgreen is offline   Reply With Quote
Old 06-19-2017, 06:59 AM   #129
soy
2001 34' Limited S/O
Crestwood , Kentucky
Tires and general
Once arriving home , we started the update to the digital world and checked function of different systems , etc. Installed new Maxxis tires on the stock 15" wheels. I don't want to get into the great tire debate, but I've run Maxxis on all of my towed vehicles ( campers ,utility and car hauler trailers ) for several years and have never had a failure. Who knows, I may try the 16" truck tires the next time. You're right on about the side loads - you can watch the rubber being scrapped of in tight turns with these triples.
Quality control must have been dismal in this era. I found 4 of the six wheel bearing torqued WAY too tight and damage to the rollers on 2 of the made in China bearings. This was on a rig with less than 4,000 miles since new. Also, 2 of the brake assemblies had never been wired up !
This is actually our second 34" Airstream - first one in late 80's and early 90's . Then went to other brands of motorhomes and trailers, and after having several bad experiences with our last trailer ( the only one purchased new ) we decided to come back to Airstream. They are the best in my book . After having the extra room with slides on our last few trailers and finding out that Airstream had made sliders for a few years, I was on a mission.
soy is offline   Reply With Quote
Old 06-19-2017, 09:50 AM   #130
GCinSC2's Avatar
Ok, maxxis I ran them for a couple years and you have prior history with them and not a total newbie.
Good start.
Old 06-28-2017, 02:40 PM   #131
2004 28' Safari S/O
Montréal , Quebec
Send a message via Skype™ to Jean B.
Slide Out Society
We have one too in Montréal, Qc, UNIT 125.
Safari 2004 28' S/O.
Nice to have discussion group like this one. i'll go through the topics and then see if i can jump in with some infos or just saying ¨Hello ¨... See U !!!
Jean B. is offline   Reply With Quote
Old 06-28-2017, 06:00 PM   #132
GCinSC2's Avatar
Jean,
Welcome to the Slide Out Society and a warm greeting from South Carolina.
Your S/OS #033
We're well equipped to advise, confuse or just outright blarney and baloney.
Gary
Old 06-29-2017, 07:18 AM   #133
mike28's Avatar
2005 28' Safari S/O
Lakeland , Florida
Saw a Classic with a slide a couple of days ago in Charleston campground. Never could catch anyone around, but it was #7777. Is this SO in our group?
Old 07-10-2017, 08:42 PM   #134
NOAZRK
NOAZRK2690's Avatar
2004 34' Classic S/O
Kutztown , Pennsylvania
Hi,
Somehow I was led to this "Society" and probably qualify as a member. In 2007 I purchased a 2004 Classic 34' with the larger couch S/O, front desk with fireplace, queen. I've been fultiming in it for 7 or 8 years. I've kept it all original so far except for putting 16" silver Eddie Bauer style wheels on it & changing over to the Dometic Blizzard air conditioners. Click image for larger version
NOAZRK2690 is offline   Reply With Quote
Old 07-10-2017, 08:50 PM   #135
STREMN's Avatar
2008 30' Classic S/O
Hampton Beach , New Hampshire
Welcome Aboard!
Originally Posted by NOAZRK2690 View Post
Hi,
Somehow I was led to this "Society" and probably qualify as a member. In 2007 I purchased a 2004 Classic 34' with the larger couch S/O, front desk with fireplace, queen. I've been fultiming in it for 7 or 8 years. I've kept it all original so far except for putting 16" silver Eddie Bauer style wheels on it & changing over to the Dometic Blizzard air conditioners. Attachment 289232
Glad to see you made it here.... wink wink
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
STREMN is offline   Reply With Quote
Old 07-11-2017, 04:55 AM   #136
2008 34' Classic S/O
Jupiter , Florida
I have a 2008 34 slide. Would like to join. We have made several interior changes including adding a splendie w/d for the boss. I will add pics when I can figure how ��
Sierradawg is offline   Reply With Quote
Old 07-11-2017, 05:06 AM   #137
STREMN's Avatar
Welcome!
Welcome to the Forums! Wow another 34 S/O...we're really packing them in now. Gary is the keeper of the numbers and he'll do the official honors of awarding the coveted S/OS #.
On the issue of photos, there's a sticky that talks about how to add a photo. It can be found in post #7 in this thread: http://www.airforums.com/forums/f138...ics-44928.html
Tom
Old 07-11-2017, 05:49 AM   #138
GCinSC2's Avatar
Wow!
Let me do the math at home tonight and announce using my pc not my phone, made too many boo boos with it.
Time to update the where we are roster too.
Gary
Old 07-11-2017, 05:40 PM   #139
GCinSC2's Avatar
Hi,
Noazrk,
Glad you were finally led in the right direction and your rig is S/OS #034
Get it, 34 for a 34! That'll cost ya extra on your semi century dues.
I spotted something missing in you pic, a hot tub. Wow that's a layout.
Safe travels and a fantastic looking rig.
Gary
Old 07-11-2017, 05:42 PM   #140
GCinSC2's Avatar
Is this a hello from your friendly slide out recruiter?
1961-1963 Airstream Bambi owners registry RichardT 1961 - 1963 Bambi 66 08-20-2022 05:39 PM
Registry - How do I add mine to AIR Registry? tomandjana97 Forum Admin, News and Member Account Info 1 07-07-2015 05:05 PM
'Secret Society'?????? jordandvm Off Topic Forum 28 04-11-2008 12:02 PM
WBCCI A Secret Society? myboyburt WBCCI Forum 35 02-28-2006 02:04 PM
