Old 02-19-2019, 07:43 AM   #21
2007 31' Classic
Gulf Breeze , Florida
Originally Posted by Adventure.AS View Post
You donít need another regulator, just a hose to connect your tank to the BBQ as the Weber Q already has a regulator.
That same thought came to me last night.
trumpetguy is offline   Reply With Quote
Old 02-24-2019, 06:48 PM   #22
Native143's Avatar
2013 20' Flying Cloud
2014 16' Sport
Dunedin , Florida
Originally Posted by Wyo Silver View Post
This is what I use. Then you can hook up anything that would normally use a 1 pound tank.
https://www.rvupgradestore.com/90-De...-p/66-8913.htm
I already have a quick connect hose hose that hooks up to my Airstream's port. But the other end does not fit the Coleman stove, ie the 1 lb. fitting. Is there are gadget for that rather than getting your suggestion. I don't want to have to unscrew hoses when I have an easier way. Thanks.
"All good things are wild and free."Henry David Thoreau
WBCCI #12814
Florida Unit #027, Suncoast Unit #129, Region 3
Save
Native143 is offline   Reply With Quote
Old 02-25-2019, 08:42 AM   #23
2019 27' Globetrotter
Denver , North Carolina
If you eliminate Coleman's regulator and use this instead
https://propanegear.com/coleman-road...t-gen-2-12-ft/
If the hose you have is long enough for you, you can convert the stove end of the hose to a LOW pressure female quick connect fitting and use this in place of Colemans regulator.
https://propanegear.com/coleman-roadtrip-adapter-gen-2/
In any event you must eliminate the Coleman regulator to use the trailer's low pressure quick connect, it converts high pressure propane (like from the 1 lb bottle) to low pressure propane.
Dave S
link2dks is offline   Reply With Quote
Propane Quick Connect Pieces & Parts Dallashayes Airstream Trailer Forums 0 11-18-2018 06:33 AM
Quick connect extra propane fitting Rich of SCal LP Gas, Piping, Tanks & Regulators 21 08-21-2016 12:10 PM
2006 Bambi 16' quick connect propane fitting? vis0rd0wn 2005 and newer - Bambi all models 8 08-20-2016 02:59 PM
Propane quick-connect callmedave LP Gas, Piping, Tanks & Regulators 31 03-10-2015 11:53 AM
A new kind of quick connect 12V outlet Westfalia Electrical - Systems, Generators, Batteries & Solar 3 09-04-2005 06:26 PM
