Old 04-05-2020, 07:45 PM   #1
2007 31' Classic
Gulf Breeze , Florida
No shore power
This happened suddenly...
Plugged into my at home, dedicated 30 amp receptacle and lost power.
Checked the power supply by plugging into the generator receptacle and got normal power.
Is there a separate fuse between the Furion receptacle And the breaker panel?
Or any other ideas?
2007 Classic 31
30 amp system
trumpetguy is offline   Reply With Quote
Old 04-05-2020, 08:51 PM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
2007 Classic - 30 amp service?
No separate plug for generator? Ergo, no transfer switch?
If using the same power cord with the generator and house current, the problem must be in the house... no fuse between cord and the converter, obviously.
House 30 amp circuit new? If so, there is the problem.
At this point I am calling the dude that installed.the 30 circuit... it is miswired or there is more than just the Airstream wired into it.
Old 04-05-2020, 10:30 PM   #3
2019 27' Globetrotter
Salem , Oregon
You may have two circuit breakers. One in the main panel where the wire to the 30 amp hook up is and possibly a breaker with the 30 amp hook up. It may be nothing more than one or both are not on.
Dave
NoResults is offline   Reply With Quote
Old 04-05-2020, 11:11 PM   #4
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
So you are saying that your trailer had two shore power connectors, and you get power with one of them but not the other?
If you have two power input connectors, you have a hidden device called an automatic transfer switch. It feeds per from whichever of the two inputs you connect into the circuit breaker box. When it fails, it usually gets stuck in one position.
I don't know if the ATS in the 2007 models can be repaired, or if you will have to replace it. Or you might have a loose wire.
The ATS is probably attached to the back of the circuit breaker box.
SSquared is offline   Reply With Quote
Old 04-06-2020, 01:47 AM   #5
2007 22' International CCD
No shore power
Bingo. Correct answer SSquared.
Sounds like a typical failed transfer switch. The fun bit will be finding it, then figuring out a replacement that fits in the space allowed...
From the department of overkill engineering:
I installed a second generator port on the front end of my 30 amp Airstream.
Upgraded to the new orange snap-in SmartPlug heavy duty Marine rated shore connectors on both ends.
I installed a manual 30 amp three position (shore-off-generator) polarity indicating transfer switch from BlueSea Systems. Less mechanical stuff to get wonky. Besides, I have full control over a switch, occasional Luddite that I can be.
The internal hard wired surge protector cleverly shoehorned behind the 120 volt breaker panel will sense, check voltage and polarity and delay the full load being dropped on the system to prevent most “hot switching” under load that eats contacts, and can extend the life of the manual switch and other components from pedestal to appliances.
Old 04-06-2020, 05:18 AM   #6
STREMN's Avatar
2008 30' Classic S/O
Hampton Beach , New Hampshire
Automatic Transfer Switch
Hi trumpetguy,
We've got a 2008 Classic 30' S/O. There are 2 30A exterior power connections on our trailer. Street side back corner and street side front...the concept being the front for a generator hookup from the back of your tow vehicle.
The Automatic Transfer Switch (ATS) is located in the rear storage compartment on the street side in the same area as the external 30A power connector.
There's a secret compartment door that pulls down from the top to provide access to the switch and it's associated wiring. Really tough working in the area with the rear hatch open and having to lean way in to get anything maintenance wise done.
I've included a photo of the switch with the compartment door open and the "manual" for the device.
All the best!
Tom - S/OS #025
Name:	ATS Location.jpg
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
STREMN is offline   Reply With Quote
Old 04-06-2020, 07:41 AM   #7
2007 31' Classic
Thanks all. I forgot to say that I added the front generator outlet plus the transfer switch. I can check the transfer switch today. It’s less than two years old so I did not even suspect it as a problem.
The 3000 watt inverter is also switched and is working just fine so it is just the factory receptacle that is not working.
Old 04-06-2020, 10:10 AM   #8
2007 31' Classic
Do you have a part number for the Blue Sea switch? I looked and all I see are manual switches.
Old 04-06-2020, 11:33 AM   #9
2007 31' Classic
So it wasn’t the transfer switch. I checked some connections and there was a wire that was just not connected as tightly as it could be so redid that and everything is all well. Thanks for everybody’s input.
Old 04-06-2020, 11:53 AM   #10
Thanks for letting everyone know what you found.
Old 04-06-2020, 12:15 PM   #11
No shore power
I did use a 30 amp manually operated Blue Sea switch because of a tight space that would not allow an automatic transfer switch.
Blue Sea apparently does not make an automatic one. The other ones available don’t seem to be particularly reliable.
Old 04-06-2020, 05:51 PM   #12
2007 31' Classic
Sorry. I miss read your posts. You use a manual switch. I can understand why.
Old 04-06-2020, 07:02 PM   #13
No shore power
Not a problem. I misread posts all the time.
In my case, the joys of getting old...and tired.
Old 04-07-2020, 07:58 AM   #14
2007 31' Classic
Dometic refrigerator won’t run on shore power& water heater light on when on shore po fotoman1527 General Repair Forum 22 04-10-2018 02:57 PM
Shore power but no battery power RogerLG Lights - Interior & Exterior 6 09-28-2012 01:53 PM
shore power/battery power wiring NavyDavesCvl Electrical - Systems, Generators, Batteries & Solar 0 10-13-2010 06:32 PM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 11:52 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
