Old 03-04-2017, 05:36 PM   #1
oldtrucksrul's Avatar
2009 27' FB Classic
Southlake , Texas
Microwave Replacement
Hello, Has anyone identified a replacement for the Tappan microwave in the 2009 27fb Classic?
Ours bit the dust recently and we'd like to replace it. I've had no luck finding one of similar dimensions.
Thanks!
oldtrucksrul is offline   Reply With Quote
Old 03-04-2017, 07:10 PM   #2
2008 27' Safari FB SE
Pfafftown , North Carolina
Unfortunately we have the same issue in our 2008 27FB Safari. We have done considerable searching for a replacement to no avail. Hopefully someone will have the solution. Thanks for posting.
sunnygirl is offline   Reply With Quote
Old 03-04-2017, 07:20 PM   #3
Long Beach , California
I have a 2008 27FB and went through this last year. If yours is configured the same as mine, look in the microwave compartment when the drawer is pulled out. On the top of the space (which is the underside of the cabinet above it), there is a small piece of wood screwed in. This was making the space too small for a microwave to slide in. It's held in place by two screws and easily removed.
Once removed, I was able to get a microwave to fit. I tried several models while the piece of wood was still there and they were all a bust. However, with it removed, I went to Best Buy and purchased the .7 CU FT Isignia compact microwave, which fit beautifully.
Hope this helps!
LBOskiBear is offline   Reply With Quote
Old 03-04-2017, 08:30 PM   #4
2009 27' FB Classic
Southlake , Texas
Lboskibear, thanks for the suggestion. I'll look into that in the morning. Do you have a model number for the microwave you purchased?
Old 03-04-2017, 09:47 PM   #5
Here's the info from the Best Buy site:
Model: NS-7CM6-BK
SKU: 2835024
It fits well and actually has less of a tendency to bounce around than the original Tappan microwave. I used the existing "holes" that were drilled for the feet of the microwave and added my own double-stick velcro tape.
My door/cabinet was starting to not latch as well (this was with the prior microwave) so I also added a baby-latch strap. It clicks in to keep the drawer from sliding out when I'm towing.
Old 03-05-2017, 05:27 PM   #6
2009 27' FB Classic
Southlake , Texas
I ordered it, lets hope it fits. Thanks!!
Old 12-16-2018, 11:03 AM   #7
2008 27' Classic FB
St. Louis , Missouri
FYI... Same challenge on our 08 classic 27FB. I suspect what you will find is that the part (ours is metal not wood) you must remove to make this microwave fit is the strike plate for the drawer latch. Removing this piece means the drawer will no longer latch for travel. We have tied the drawer closed with a bungee for travel, but still looking for a microwave with acceptable dimensions. It needs to be something like 9.8 inches high — I plan to make an exact measurement next trip.
Skrausestl is offline   Reply With Quote
Old 02-04-2019, 02:33 PM   #8
2008 27' Classic FB
Finally got out to measure the microwave drawer... The maximum height of a microwave must be be 9 5/8 inches to allow the stock drawer latch to function and to allow the microwave to slide under the latch mechanism. We haven't found a microwave that size yet... Would love to know if anybody has found one.
BTW the drawer can accommodate an oven that is no more than 13 1/2 inches front-to-back.
Old 02-04-2019, 03:23 PM   #9
We're looking for the answer too! Will be following the thread.
Old 01-16-2020, 04:11 PM   #10
Dkoelfgen's Avatar
2011 27' FB Flying Cloud
Albertville , Minnesota
I see this kind of an old thread but here is what I did.
Our 2011 27' FB Microwave in the slide out drawer died.
I checked Airstream, approx. $300.00 to order a replacement.
I checked Amazon, bought a Comfee EM720PL-PM
It fit perfect, even the feet lined up with the counter bores in the Microwave drawer.
It works great! $70
DK
Dkoelfgen is offline   Reply With Quote
Old 01-22-2020, 07:33 PM   #11
It works great! $70
DK
I would appreciate if you would provide the height measurement from the shelf that the microwave sits on to the top edge of the door. I suspect this dimension may be different in my trailer since Airstream started using a different brand microwave about 2010. Thank you so much.
Susan
Old 01-23-2020, 09:38 AM   #12
Dkoelfgen's Avatar
If you go on Amazon it gives the Microwave dimensions.
The distance from the slide-out Microwave drawer surface to the top edge of the drawer face is 11" on our 2011 27' FB.
I would think it is the same on your 2010.
Doug
Old 01-23-2020, 09:41 AM   #13
2009 34' Panamerica
2005 28' Classic
Still , in the thick of it
Sort of related. I was looking at microwaves a few days ago and found several RV sized *convection* microwaves. Any real benefit to one of these vs a standard microwave?
https://www.amazon.com/Built-Microwa.../dp/B012U50G7E
panamerican is offline   Reply With Quote
Old 01-23-2020, 10:16 AM   #14
2012 25' FB Eddie Bauer
2009 19' International
Aptos , California
A convection microwave uses microwave energy to heat and cook food plus a fan to circulate the heated air. Food cooks faster and browns more like a conventional oven than a simple microwave. The proof of a convection microwave ovens value is revealed when you cook a chicken. It’s dramatically better in a CMW oven. Now back to the original thread with apologies for the brief hijack...
brad1 is offline   Reply With Quote
Old 01-23-2020, 10:34 AM   #15
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Originally Posted by brad1 View Post
A convection microwave uses microwave energy to heat and cook food plus a fan to circulate the heated air. Food cooks faster and browns more like a conventional oven than a simple microwave. The proof of a convection microwave ovens value is revealed when you cook a chicken. Its dramatically better in a CMW oven. Now back to the original thread with apologies for the brief hijack...
+1, just to clarify; in convection mode, the microwave, uses microwaves to pre heat air, which is then blown around the food, allowing it to sear, cook and brown food, versus microwaving the food directly.
Cheers
Sidekick Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 01-23-2020, 11:51 AM   #16
Mollysdad's Avatar
Remember, the microwave has a magnetic switch to shut the power off if the drawer is closed. (or at least mine does). It may be above the unit and requires a bit of space.
If mine was any larger I don't think the door would open.
Old 01-23-2020, 02:30 PM   #17
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I can't speak for other floorplans, but that switch in a 26U is under the drawer rather than above the microwave, so it shouldn't eat any of the available space between the floor of the drawer and the top of the interior of the cabinet.
David
DKB_SATX is online now   Reply With Quote
Old 01-24-2020, 05:14 AM   #18
It works great! $70
DK
Thank you so much. I appreciate your help.
Susan
Old 01-24-2020, 08:24 AM   #19
Mollysdad's Avatar
Thanks for setting me straight!
microwave compared to a convection microwave. Happycampers Airstream Motorhome Forums 6 02-23-2016 10:58 PM
Anybody replace their microwave to convection microwave in a 16 sport scamp 2005 and newer - Bambi all models 0 07-10-2014 04:34 AM
Replacement Microwave for 2007 Safari 23 SE ncairstreamr Stoves, Ovens & Microwaves 2 04-28-2013 08:35 AM
Samsung MR5471G microwave replacement Dwight Stoves, Ovens & Microwaves 0 11-11-2012 11:44 AM
Microwave Replacement steptex Stoves, Ovens & Microwaves 1 10-01-2012 06:35 PM
