09-22-2019, 07:26 AM
2007 31' Classic
Gulf Breeze
Blue Ox Sway Pro
I like my Blue Ox but I may have the wrong drop shank because my trailer rides a bit nose up and I have not been able to correct this with the seven hole shank turned upside down. Are there other owners using the Blue Ox who use either the nine hole or eleven hole shank.
2016 Ram 2500 TBD with air suspension
2007 Classic 31
Tongue weight is 1075
Using 1500 pound bars
Receiver height 21.5 inches
09-22-2019, 07:37 AM
2018 27' Globetrotter
Apollo Beach
Yes. I have all three 7, 9, 11 hole. The nine hole works for the new F250 4x4 which is fairly tall - almost lifted. The 11 hole would work for lifted trucks. I cut my 11 hole to a ten hole. Now it’s the same length as the nine hole but has one extra hole. I am using a Propride now but still have my Blue Ox. I like the simplicity of the Blue Ox. It works well, just not as good as the Propride on my new F250.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
09-22-2019, 07:39 AM
2007 31' Classic
Gulf Breeze
Thanks. So you think the 11 hole would solve my problem?
09-22-2019, 07:44 AM
Apollo Beach
Yes, you can buy an 11 hole and easily cut it down to the same length as a 9 hole if it’s too long. Your Dodge is tall. The 11 hole should work.
09-22-2019, 08:41 AM
2015 23' Flying Cloud
Copper Hill
, Virginia
Have you considered a lift kit for the airstreams?
09-22-2019, 09:23 AM
2014 25' Flying Cloud
Temple
I bought the nine hole for my new Ram 2500, the seven hole resulted in our AS being about 3 inches too high in front. I have not hooked it up yet but I expect it to be right on level based on my initial measurements of the new ball height.
2014 Flying Cloud 25FB
2018 Ram 2500; Cummins
Blue Ox WDH
09-22-2019, 09:29 AM
2019 27' International
Western NC
, North Carolina
9 was too short for our F350 went to an 11.
2023 Van Leigh Vilano 320GK
2019 International Serenity 27 FBQ “TC Escape” SOLD
2019 Ford F-350 Platinum
09-22-2019, 10:25 AM
Copper Hill
, Virginia
A lift will give you extra 3 inches of clearance, just sayin.
09-22-2019, 11:28 AM
2020 30' Flying Cloud
2020 FC 30 Bunk
, Georgia
I have almost the same truck, 2015 also with rear air. Don’t forget that you can lower the truck an inch or two using the Alt Trailer height switch. I usually do that. I use a 9 hole drop and am level pulling a 30 Bunk.
09-22-2019, 11:34 AM
2020 30' Classic
2016 30' Classic
Covington
, Louisiana
I have a 2015 F250 diesel. I’m not aware of the trailer height switch. How do I access the switch?
09-22-2019, 11:48 AM
2007 31' Classic
Gulf Breeze
Thanks for the reply. I do use the Trailer Height toggle but it is still too tall for the AS.
Looks like I will be buying the 11 hole shank. At $150 <> it’s a reasonable solution.
09-22-2019, 11:50 AM
2007 31' Classic
Gulf Breeze
I have thought about doing the lift. That will help with those diesel stations having a steep drop.
Do you know which kit works on our trailers.
09-22-2019, 12:07 PM
2019 27' Globetrotter
McHenry
Using a Curt Drop Shank from eTrailer
2007 Classic 31
Trumpetguy, I moved from a Ram 1500 to 2500 and ended up with a Curt 2.5” receiver, 12” rise, 8” drop drop shank and it works great with our Blue Ox Sway Pro.
Hope this helps!
Jeff
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
09-22-2019, 12:51 PM
2007 31' Classic
Gulf Breeze
Man...that’s not much ground clearance.
09-22-2019, 12:53 PM
2007 31' Classic
Gulf Breeze
I don’t know about the Ford. Ram has a dash button labeled Alt. Trailer Height.
09-22-2019, 01:25 PM
2007 31' Classic
Gulf Breeze
Blue Ox offers two drawbar options...9 inch or 12 inch long. It would seem the 12 inch would help with jackknifing. Any thoughts from the forum members?
09-22-2019, 04:22 PM
2015 25' FB Flying Cloud
Texarkana
I have the 7-hole shank for my 2014 Ram 1500 4x4 pulling 2015 FC25FBT with 1,500 bars ... set up in Pender, NE by Blue Ox. Maybe Chad Luber @ Blue Ox can provide some input ... 402-385-2851. Good luck!
09-22-2019, 04:32 PM
McHenry
I was waiting to trim the last 1.5” off the shank but didn’t have any trouble on a 2400 mile trip to Rocky Mountain National Park. *The jack foot was down for the photo - it’s normally way above the shank. The 2500 sits 3” higher than the 1500 it replaced.
2018 FC23FB
WBCCI# 10258
RETIRED!
09-22-2019, 06:36 PM
2018 27' Flying Cloud
Delray Beach
I can’t honestly tell you about your Blue Ox, but I can tell you that ProPride is absolutely amazing. I personally teach customer service for a living, and Sean and his team are the “Gold Standard “ when it comes to support (before, during and after the sale). These guys are awesome.
09-22-2019, 07:02 PM
2007 31' Classic
Gulf Breeze
Thanks for that input.
