Old 12-26-2021, 06:43 PM   #1
2010 25' FB Flying Cloud
Snoqualmie , Washington
any limit on snow on roof?
My kids are over and staying in our 2010 25' FC parked at our house (have electricity to it); since there is too much snow for them to get to their house. We currently have 2 feet of snow on top of the airstream, and it will continue to snow hard - so I can easily see at least 4' of snow on top. Any issues with that much snow? (and yes it is winterized).
Anders79 is offline   Reply With Quote
Old 12-26-2021, 07:43 PM   #2
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
Wow, you got a lot of snow!! We live in Kingston and got maybe three inches.
Anyway, no, I do not think that is an issue with your Airstream. If a 200 pound person can walk on the trailer roof, I suspect your evenly distributed snow load will not be an issue.
10Smiles is offline   Reply With Quote
Old 12-26-2021, 09:07 PM   #3
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
If it’s truly 4’, that’s a ton of weight. I would try to brush some of it off…a 550+ cfm leaf blower can work miracles.
- Stewart
s1000pre is offline   Reply With Quote
Old 12-26-2021, 09:34 PM   #4
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
I'd try to get some off with a broom or snow rake. Like s1000pre said, that's a lot of weight.
Last year I tried to keep our solar panels clear for the batteries but eventually gave up and connected a trickle charger.
Side note: We're still waiting for our first measurable snow in Northern IL, setting a new record. Crazy weather patterns this year.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 12-26-2021, 09:43 PM   #5
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
Are the vents clear ?
Old 12-26-2021, 09:49 PM   #6
CBWELL's Avatar
2010 30' Classic
Warren , Manitoba
If it's dry fluffy snow it's not too bad, but if it's heavy wet snow get as much off as possible. A leaf blower works great! Be careful using any metal tools as you might damage the roof by scratching.
ACI #7394
2012 GMC 2500 HD Duramax Denali
2010 Classic Limited 30' ,1994 Excella 34'
1987 Limited 34', 1976 31' Sovereign, 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is online now   Reply With Quote
Old 12-27-2021, 10:10 AM   #7
2012 23' FB International
Woodstock , Ontario
I would be more concerned for the suspension and stabilizers
4 ft of snow is a lot of weight. That’s like adding 4 or 5 inches is water inside your AS
JCWDCW is offline   Reply With Quote
Old 12-27-2021, 10:17 AM   #8
2021 27' Globetrotter
Tallahassee , FL
I can appreciate the good comments on that much snow on your AS bit how.much snow is on your homes roof? 4 feet is a lot.of weight for either one.
Kawboy01 is offline   Reply With Quote
Old 12-27-2021, 10:30 AM   #9
"Cloudsplitter"
After 17yrs here in the Lake Erie snow belt we've had no sno damage/concerns.
POI I do remove the wheels for winter storage.
2014 80" in three daze.
ID:	409828   Click image for larger version
ROBERT CROSS is online now   Reply With Quote
Old 12-27-2021, 10:55 AM   #10
ended up not as bad as i thought (but by the end of the week we shall see). Thanks for the feedback - guess today i will try to go at it with a broom.
Old 12-27-2021, 11:06 AM   #11
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Best get most of it off…
Old 12-27-2021, 03:27 PM   #12
2016 19ft flying cloud
Spokane , Washington
Inches or ft?
Doesn’t get 4 ft of snow in Seattle over twenty years
Spinonedad is offline   Reply With Quote
Old 12-28-2021, 01:27 AM   #13
we are at the base of Mt Si - so 4 feet is possible, but it did end up stopping and thus, not that bad. I did remove most of it.
Old 12-28-2021, 09:29 AM   #14
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Good good. A cubic foot of snow can weigh anywhere from. 1-20lbs depending on moisture content.
8’ wide by 20’ long by 4’ is 640 cubic feet (back of the envelope).
wulfraat is offline   Reply With Quote
Old 01-02-2022, 10:23 AM   #15
MARILLA , New York
I know that storm Bob. As a fellow WNYer, we've never had an issue either. That particular storm, we were had 7ft on top of our previous fiberglass box trailer. If that trailer could hold up, an Airstream will do just fine. People are more likely to cause damage trying to remove the snow, rather than just leaving it.
Nicdem79 is offline   Reply With Quote
Old 01-02-2022, 11:14 AM   #16
2020 27' Globetrotter
STAMFORD , Connecticut
Last winter (2021), I had an extended stay in Canada and I cleared the snow off my Airstream almost every day, using a short step ladder and a snow brush. I don't think it is a good idea to allow it to accumulate. Even if the weight is not a concern, it's an opportunity for expansion and contraction to do damage and for moisture and condensation to build up. Why risk it?
btw, if you have people staying in the AS in winter, you best be taking active measures to reduce/eliminate condensation.
Justinfinity is offline   Reply With Quote
Old 01-02-2022, 11:43 AM   #17
gator.bigfoot's Avatar
KW , Ontario
I use a snow rake just to keep the solar panels clear. Otherwise I leave it on the rest of the unit.
gator.bigfoot is offline   Reply With Quote
Old 01-05-2022, 09:39 AM   #18
North Fayston , Vermont
WE use a push broom or wooden hay rake to pull the snow off after 6 inches. I also don't want the warming and freezing on the roof, the snow melt could find a seam to leak into the trailer.
northfayston is offline   Reply With Quote
Old 11-28-2024, 08:18 PM   #19
1989 29' Excella
Buckhorn , Ontario
Were you ever given an answer?
Excella As is offline   Reply With Quote
Old 11-29-2024, 08:19 AM   #20
Woodstock , Ontario
I can see 4 feet of snow potentially overloading the
Suspension or the stabilizers
I wouldn’t be worried about 2 feet
How much snow is too much snow? KSA63 Winterizing, Storage, Carports & Covers 43 02-19-2017 05:20 PM
Can your airstream roof stand up to the snow? wacnstac Roof 5 10-01-2010 06:05 AM
And the snow zinged off of the roof and piled against the Airstream….. darlingbooks Winterizing, Storage, Carports & Covers 30 02-15-2009 02:13 PM
Snow and SNOW.. 53flyingcloud Off Topic Forum 9 01-23-2005 03:32 PM
Airstream Labyrinth / Time limit on Post Composition ?? hex Forum Admin, News and Member Account Info 5 09-20-2002 03:27 PM
