Old 06-18-2019, 04:57 PM   #1
2007 31' Classic
Gulf Breeze , Florida
30 Amp Furion plug
I will be installing an additional power inlet for my generator. I will also install a new auto transfer switch. The inlet will be on the front of the trailer so I can leave the generator in the truck with a short run to the inlet.
My question is about sealing the plug. I have several sealants on hand...Sikaflex, Vulchem, GE Red Silacone, and Parbond for aluminum. My inclination is to use Par Bond because I can apply it with a very fine bead.
Any suggestions for sealants?
trumpetguy is offline   Reply With Quote
Old 06-29-2019, 08:00 AM   #2
2007 31' Classic
The furion came with a rubber gasket that should do the trick. I ran a bead of Par Bond just make sure. Nice to have the extra plug on the nose of my AS.
Furion 30A plug recall jbxx Batteries, Univolts, Converters & Inverters 5 09-17-2015 07:12 PM
to plug in or to not plug in...that is the questions 4hartungs Batteries, Univolts, Converters & Inverters 39 04-23-2014 03:44 PM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
