04-27-2016, 05:40 AM
1969 27' Overlander
Sebring
Water tank filler cap
A new challenge has developed as the filler cap on the water tank seems to be fused on the pipe going into the trailer. I have applied WD-40 and a pipe wrench and it will not budge to the point that the outside aluminum would start to bend.
Any ideas how to get this thing unstuck?
John
04-27-2016, 06:21 AM
1955 22' Safari
1967 26' Overlander
Clear Lake Shores
Ideas
1. Try spraying it with a product called PB Blaster (available at AutoZone, Home Depot, etc). Best product I have found for freeing corroded parts.
2. If that fails, you can try using a torch to carefully heat the metal which should break the corrosive bond.
04-27-2016, 06:35 AM
1966 22' Safari
Hilltop Lakes
Word of advice about that water filler cap...
When you do get it loose, make it a habit to put it in your pocket (and nowhere else) every time you remove it from the filler neck. Inland RV stocks replacements in case you do what I did before I made this rule.
04-27-2016, 09:43 AM
1969 27' Overlander
Sebring
Thanks, on my way to HD to get the solvent later today
04-27-2016, 10:54 AM
Airstream - Other
Bosque Farms
, New Mexico
Those things can be a pain on ours, too. Wondering if a coating of bee's wax might help in the future.
Lynn
WBCCI 21043
04-27-2016, 11:02 AM
1977 31' Sovereign
Lynnwood
PB Blaster works great. But I wouldn't want it in my drinking water.
I'll bet the gasket has rusted to the filler neck. Boiling water has a way of loosening things like that.
To prevent future seizing, and as a measure of routine maintenance, the cap needs to be removed periodically. A light coating of vegie oil wouldn't hurt either.
Tom
04-27-2016, 11:43 AM
Airstream - Other
Bosque Farms
, New Mexico
You know, another simple lubricant we have used is plain, unscented hand soap.
WBCCI 21043
04-28-2016, 02:33 AM
2003 31' Classic
Terra Alta
, West Virginia
Plumber's grease.
04-28-2016, 03:01 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
White food grade grease.
2014 31' Classic model 30 twin beds, 50 amp service, 900 watt solar system, Centramatics, Tuson TPMS, disc brakes, 16" tires & wheels
04-28-2016, 07:42 AM
1969 27' Overlander
Sebring
Well it is still stuck, and the PB Blast didn't have any effect, I'll try the torch later today, very frustrating.
I may wind up cutting it off, re-threading the pipe and get a new cap.
Thanks for the ideas.
John
04-28-2016, 09:47 AM
Airstream - Other
Bosque Farms
, New Mexico
No fret. You can buy a new water fill neck with cap. I think that VTS may stock them, but shop around, including on ebay. And put some non-toxic lubricant on the new one.
Lynn
WBCCI 21043
