Old 12-06-2011, 09:44 AM   #1
macstrange's Avatar
1968 26' Overlander
Tucson , Arizona
Vin # location
Hey all,
I need to know where the vin # is located on an overlander I'm about to purchase.
macstrange is offline   Reply With Quote
Old 12-06-2011, 09:49 AM   #2
Sphere Guy's Avatar
Livingston , Texas
Try looking in the tongue area on the Aframe.
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 12-06-2011, 09:50 AM   #3
Originally Posted by macstrange View Post
Hey all,
There should be a plate forward of the door.
But, different years have different places.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-06-2011, 10:10 AM   #4
macstrange's Avatar
1968 26' Overlander
Tucson , Arizona
Thanks. I have to call the lot attendant and let her know so she can find it. I need to get temp registration so I can pick it up on sat.
Old 12-06-2011, 04:12 PM   #5
macstrange's Avatar
1968 26' Overlander
Tucson , Arizona
OK, attendant checked tongue a-frame and didn't find any 8 character codes. Just one 7 character code. 2 six digit #s seperated by one letter (000x000). The airstream web site lists some 7 character codes in the 60's catagory, though none match. Of the #s listed none have an "A" in the code. I'm stumped.
Shawn Bradley
Old 12-06-2011, 05:13 PM   #6
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Is the trailer a 1968?
Shawn, If the trailer is a '68 there should be a model/manyfacturer plate just to the right (forward) of the main entry door. It will have the model name displayed and the serial number should be die stamped into a recessed area of the plate. Hope this helps. Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 01-11-2012, 03:22 PM   #7
apexdc's Avatar
1968 30' Sovereign
Palm Springs , California
I am trying to get my 1968 registered in California coming from New Mexico. I have the plate by the door with 1308J733, which is what is on the title.
However, California requires two locations. I have scraped most of the paint off the top of the a frame, removed the equalizer mounts, etc. and found nothing. Even tried looking under the propane tanks. On the road side, there is a large number shown that doesn't seem to relate to anything. I looked under and around almost any other logical locations and still nothing.
Should I just give up? Am I looking for something that doesn't' exist?? DMV wants two locations or I think they assign a new VIN.
Thanks for any advice on this.
ID:	148738   Click image for larger version
ID:	148740   Click image for larger version
apexdc is offline   Reply With Quote
Old 01-11-2012, 04:46 PM   #8
SteSpot's Avatar
1982 24' Airstream 240
Ventura , California
CA DMV......go to another one..
Our 68 Ambassador is registered in CA with one VIN location......we found our local DMV to be clueless.....We found that different DMVs have different rules and charges....go figure. We found Thousand Oaks to be okay. They verified our 69 Overlander from Arizona...did not ask for 2 locations..and they are a California DMV....also, you don't want a different vin....yours tells the length (I think-is it 30 '?), the year 8 for 68, J for Jackson Center and #733 off the line.....paula
Paula & Ed
WBCCI # 8252 Air#13593
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 01-11-2012, 05:36 PM   #9
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
You might try taking them a close-up of the ID plate....
Ive always thought that over planning was just a firewall against not being sure of what you really want to do.
RLC
Tahawus
Old 01-11-2012, 06:29 PM   #10
apexdc's Avatar
1968 30' Sovereign
They will have a CHP officer come by and check the plate (shown). The problem is if they require two numbers to be on the trailer.
I can only find one.
Old 01-11-2012, 08:28 PM   #11
SteSpot's Avatar
Don't even mention two locations.....
You just need one location.....someone has some misinformation....I was worried about our 82 24' MH that had a 15 digit VIN from Florida....before that only a 15 digit VINs were necessary in CA....not a problem....I worried needlessly for 2 weeks.....
Paula & Ed
Old 01-11-2012, 08:30 PM   #12
SteSpot's Avatar
Are you sure it is an Overlander?
How long is it including the hitch?
Paula & Ed
Old 01-11-2012, 08:36 PM   #13
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Get your self a piece of flat stock aluminum about 1 1/2" x 3". Write down the VIN number on a sheet of paper. Take the aluminum plate and the paper to a jeweler and have the plate engraved with the VIN #,s.
Take it home, paint it, wait two or three days, sand some of the paint off, scrub it with a scotch brite pad. Pop rivet the plate to the tongue somewhere inconspicuous. Now you have a VIN # in 2 locations. Next step; call the CHP.
Old 01-11-2012, 09:26 PM   #14
SteSpot's Avatar
You have a Sovereign not an Overlander
30' makes sense now.....Overlanders were under 26', Ambassadors were 28' and Sovereigns were 30'...it says on your face plate.....they are all Land Yachts of that year..
see this website: View RVs .com - 1968 Airstream Travel Trailers
Paula & Ed
Old 01-12-2012, 12:06 AM   #15
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
It's a 30' Sovereign
Find a local tool and die shop. They can make you up a die set with the VIN# off your model/serial plate to the right of the door and have them stamp it on the A-frame. The best place is on the inside of the A-frame on the curbside between the clamp bracket for your anti-sway and the front of the trailer. That way once your tanks are installed the numbers will be in a very hard to see spot except for the people who know where it's stamped. The larger numbers on the outside of the A-frame on the streetside are a supplers part number for the A-frame assembly. Once it's on the frame wire brush it to put a little wear on the edges and paint it black. Then remove the surface black paint and Voila' you have a second location. No one ever said it had to be "Factory". Everyone is happy and you can register and title in California! Ed
P.S. Check the first digit to make sure it is a 1. My trailer is a '67 and the first digit of my serial is an I which means it has the International trim package. If it was a standard trim package that first digit would be a O. Hope this helps, Ed
We can't locate the original vin# on our 1966 Tradewind Adams 1959-69 Tradewind 9 01-14-2012 11:55 PM
LP Tank holder location my3sonsdad LP Gas, Piping, Tanks & Regulators 1 11-26-2011 10:47 PM
Looking for VIN Melinda Title, VIN & Registration 4 09-27-2011 07:05 PM
Vin in frame? qc1500 Title, VIN & Registration 2 08-20-2011 07:12 PM
VIN doesn't match Airstream guidelines casa3805 Title, VIN & Registration 1 04-02-2011 12:49 PM
