Old 05-27-2012, 09:28 AM   #1
1966 26' Overlander
Conover , Ohio
time to test
After a rear floor, adding A/C, and new axles I'm about to lay vinyl and start putting my 66 back together. Before I go much further, is there an easy way to "bench test" my appliances. I'm ditching the oven for a microwave, so I just need to check the fridge, furnace, toilet, and water heater. The furnace is a Suburban Dyna-Trail, the water heater is a Bowen G110T, the fridge is a Dometic 510A, the toilet is ...well, a toilet.
A side question. There is an on/off switch above in the wall above the oven, is that for the outside light...or water pump is my second guess?
Thanks, TomE
project66 is offline   Reply With Quote
Old 05-27-2012, 07:59 PM   #2
1966 26' Overlander
Conover , Ohio
I stand corrected. The tiolet is an Aqua Magic by Thetford. It cleaned up well. Is there anything in particular I should look for on any of these appliances?
Thanks TomE
