Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1965 - 1969 Overlander
Old 02-22-2016, 03:39 PM   #1
ChuckZ's Avatar
1966 26' Overlander
2012 28' Flying Cloud
Waukesha , Wisconsin
Sconce bulb replacement
OK, it's just me again. Now I have a question about replacing a bulb in one of my wall sconces. I just know that it should be a no brainer but for some reason I just can't get the old bulb out. Try as I may, I can't seem to get that stinker out. I assume that it's a typical bayonet mount 12V bulb but I guess that my fat fingers just aren't getting a grip on it. I can push it in a little but no twist to be had. I've tried to remove the bulb from other working sconces but no luck there either. Is there a trick? Or do I just need to find a child with small hands and the grip of a gorilla?
ChuckZ is offline   Reply With Quote
Old 02-22-2016, 03:49 PM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
try some PB Blaster or similar lube, and a cloth to hold onto the bulb. Its probably corroded in there
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 02-22-2016, 04:10 PM   #3
Retired.
. , At Large
Yes. DO NOT hold the bare bulb. It will shatter in your fingers, with painful results. The Voice of Experience here...
Old 02-22-2016, 05:36 PM   #4
ChuckZ's Avatar
1966 26' Overlander
Thanks for the tips. I'll try the Blaster and cloth.
Old 02-22-2016, 06:35 PM   #5
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Bulb removal
The problem is most likely that the bulbs are corroded in the sockets. The easiest way to remove them is to break the glass and use Break Free or P B Blaster on the sockets. Then use a pair of needle nosed pliers in the center of the bulb to push down and twist the bulb base to release it from the socket. A larger bulb and you would be able to use a potato o accomplish the same thing. Ed
P.S. You will need to clean the socket up to allow proper contact for the new bulb base so the light bulb will work right.
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 02-23-2016, 11:25 AM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I would also suggest you squirt a bit of the Blaster or electronic contact cleaner/lube, into each bulb socket your trailer has so this job will be easier in the future.
AIR #005
retired!
turn signal light bulb replacement...bulb not turning ArgosyMinuet All Argosy Trailers 5 01-01-2021 10:21 PM
Serenity Wall Sconce Bulb Hoonanea Lights - Interior & Exterior 3 11-27-2012 06:26 AM
1960 Wall Sconce Lighting mmth11053 Electrical - Systems, Generators, Batteries & Solar 3 03-30-2006 06:52 PM
Restore Wall Sconce Light Fixtures mmth11053 General Interior Topics 0 03-22-2006 10:13 AM
