Old 07-28-2008, 09:48 PM   #1
Saggy axle pics
I read Andy's article checking if your axles are worn out yet. This is where my unloaded 67' overlander sits.
P1000283.jpg - Image - Photobucket - Video and Image Hosting
Are these borderline ready to be replaced?
bvanetten is offline   Reply With Quote
Old 07-28-2008, 09:59 PM   #2
The rear axle photo shows that it's borderline.
When the torsion arm is parallel to the chassis, "when the trailer is fully loaded" the axle is on it's last leg.
Your torsion arm, shows a slight downward angle, but I assume that the trailer is empty.
As weight is added to the trailer, that torsion arm will move upwards, since they are weight sensitive.
Anytime the torsion arm is parallel to the chassis, when the trailer is empty, is almost a guarantee that when the trailer is loaded, the torsion arm will angle upwards from parallel.
The other test is to jack up the trailer on one side. The tires should drop about 3 inches. If they do, then the rubber rods are OK. If they do not drop that much, then the rubber rods have solidified,
Andy Rogozinski
Inland RV Center
Corona, CA
Another saggy door story Siddhartha Doors & Locks 5 07-24-2008 07:37 PM
Saggy bathroom csham General Repair Forum 12 03-21-2008 05:37 PM
Before & After Axle Pics Smokin Camel Axles 39 08-01-2007 12:12 PM
Saggy Bottom RONALD DODA Interior Restoration Forum 3 06-02-2005 07:42 AM
Saggy As$ '72 J-n-A Our Community 1 08-08-2003 11:10 AM
