Old 09-06-2009, 08:30 PM   #1
1967 26' Overlander
Simpsonville , South Carolina
Running Light Problem-Help!
Hey everyone,
My front orange running lights, my passenger side rear light, and license plate light work....but my drivers side rear light and upper rear red running lights don't work now. Brake lights and turn signals work both sides. What is going on?
Does anyone know how the rear lights are routed on a 67 Overlander? I'm chasing wires tommorrow am....ugh.
Tim
TCHANNEL is offline   Reply With Quote
Old 09-06-2009, 08:33 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
First off, welcome to the Forums. We're glad to have you with us.
As far as your lights go, are the bulbs all good?
brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
Old 09-06-2009, 08:37 PM   #3
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
I think your wires come from the curb side, so I'd remove the can for the light on both sides and check all the connections, because if a wire is broken on the passanger rear tail light it very well could not allow it to work on the street side rear and top. Of course as Brian pointed out, double check all bulbs etc and clean grounds before pulling other things apart. Welcome to the forums as well!
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 09-06-2009, 09:08 PM   #4
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
Welcome to the forums!
You say they aren't working now, were they working before? I agree with the others that I would start with the basics and move up.
My upper rear red and front amber run in series
Alwhisman is offline   Reply With Quote
Old 09-06-2009, 09:14 PM   #5
1967 26' Overlander
Thanks guys....Yep, the wires look to come up from the bottom of the curb side...to the curb side can. The green wire feeds the curb can, branches to the license plate light, and maybe to the street side can. When I take the street side can off, I see a green wire headed towards the curb side, and a wire headed upwards to possibly the upper running lights. Does anyone know if the green leaded is tied to the license plate light and the street side can at the curb side can? I don't see anyway to get in there and sort out the wiring.
I have a hunch the street side can came loose behind the panels.
Tim
Running light leaks BDandTTs General Repair Forum 3 08-31-2009 07:10 AM
Running light problems Wayner 76 Lights - Interior & Exterior 3 05-29-2008 07:30 AM
running light corrosion altamont Lights - Interior & Exterior 4 05-20-2008 08:03 AM
Running Light Leaks bhunt Lights - Interior & Exterior 4 05-15-2006 11:18 AM
Running light question jcferguson Lights - Interior & Exterior 9 11-01-2005 09:07 AM
