Old 07-28-2008, 09:54 PM   #1
Plumbing, AC, and Stove Roof Vents
Does anyone make aluminium vents for the three types of holes in my 67? I havethe idea of putting molded plastic back on. I've searched and have not found one yet.
bvanetten is offline   Reply With Quote
Old 07-28-2008, 10:15 PM   #2
The square vent holes originally, in your trailer, had metal covers. Those covers have not been available for years. That cover was called a solardome.
Airstream later cut out the center of those covers, to let light in the trailer. That was so successful, that they did away with the metal covers and went to total plastic covers, to let a maximum amount of light into the trailer.
The rectangular cover is called an astrodome. It never was made of metal, but always plastic.
There are plastic covers that have a thermal barrier built into them, both in white and solar gray, for both the astrodome and the solardomes.
Those are after market and are available from one source. Free gaskets for them are included.
The solar gray lets in far more light, but no more UV than the white covers.
Sewer vent pipe covers are now metal, as used by Airstream for over 30 years. You must use a gasket and screen with them.
The stove exhaust vent cover, is available made with fiberglass, which far outlasts the plastic type.
The reefer vent cover is available made from stamped aluminum, as used by Airstream for almost 40 years.
Andy Rogozinski
Inland RV Center
Corona, CA
Roof vents KeithC Roof Vents, Skylights & Fans 2 05-21-2007 04:43 AM
Plumbing Vents - Useful Info lebolewis 1974 - 1979 Sovereign 0 07-07-2006 06:22 PM
Roof vents skidmark Roof Vents, Skylights & Fans 6 08-30-2005 04:25 PM
Roof Vents tmeagle1 Roof Vents, Skylights & Fans 6 01-10-2004 04:49 PM
Roof vents? aviontt Roof Vents, Skylights & Fans 10 10-05-2003 07:31 PM
