Old 05-01-2019, 03:36 PM   #1
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Need help on 1967 26í Overlander.
Iím redoing my 67 and have lost or erased my photos of the bath sliding door where it hits the sink side cabinets. There are two closets on the curb side . One in bath and one at the end of the bed . Iím wondering what the trim there looks like and where the door stops ?
Any help would be helpful. Thanks , Blue .
Joyflea is offline   Reply With Quote
Old 05-01-2019, 09:02 PM   #2
1966 22' Safari
Fredericksburg , Texas
Was the door a sliding or bifold? In our 66 itís a bifold. Just wondering.
Bubba L is online now   Reply With Quote
Old 05-01-2019, 09:36 PM   #3
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Sliding , Bubba .
Old 05-02-2019, 09:12 AM   #4
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
'67/'68 GT thru Sovereign baths are similar. The '68GT pocket door simply butts up to the melamine face of the closet in the bath. There's no jamb, stop, or casing.
On the OverLander, there may be a strip of wood trim to cover the transition from the melamine face to the face of the forward adjoining closet. It could stand proud of the wall enough to mimic a jamb, and cover the door to wall gap. On the GT, there's a 90 degree 1/2” wood corner trim from floor to ceiling, as that's where the kitchen bulkhead is. In the photo, the upper half has been replaced with 1/2” aluminum angle.
There isn't anything vertical that the door actually nests into when it is closed. There was a toe-stubbing 1-1/2” U-shaped plastic that was mounted to the floor next to the melamine closet that was intended to hold the door bottom in place when closed. I didn't keep it, it wasn't necessary, looked ugly and cheap.
Sorry these photos don't help much with the explanation. I permanently removed the overlaid bath closet door, I didn't agree with its swing. Cased the opening with ash, lined it with aromatic cedar, and made a his/hers clothes bin in bottom.
Alignment-wise, things were originally VERY out of square-level-plumb. I think someone could figure a number of ways to improve it. The upper glide rail and nylon rollers are marginal in quality and function. My nylon rollers were no longer round, required truing. In retrospect, I'd start with a better quality glide rail, and not follow Airstream's chintzy design.
The pocket can be troublesome. With humidity over the years, the bath wall, which is faced with melamine on the bath side, but unsealed plywood inside the bulkhead, warps/bows into the pocket, causing interference with door. My original door was seized into the pocket. Making a thinner door was part of the best solution for me.
Here's a link to my pocket door adventure, with better explanation.
http://www.airforums.com/forums/f7/p...ce-128019.html
ID:	339583   Click image for larger version
ID:	339585   Click image for larger version
ALUMINUMINUM is offline   Reply With Quote
Old 05-02-2019, 11:35 AM   #5
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Here is a pic from TomW's 67. Shows the door area. Tom's a buddy and helped me when I did my 68, send him a note and I'm sure he will send you more pics if you need them.
http://www.knology.net/~tcwilliams/Bathroom1.htm
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 05-02-2019, 02:34 PM   #6
NO HUMBLE OPINION
Hmmmmmm...
OK,
I looked in the Airstream's document floor plans for 1967. There could be a difference in the Twin vs Double. The '67/'68 bath came with either a closet, or an extended, wider sink countertop.
If you have the wide countertop without the closet in the bathroom , it might be different than what I described.
I'd still trust my instincts, and build it out in a way that makes sense, as there's often a better way than Airstream's "economical" configuration.
Old 01-26-2020, 08:48 PM   #7
chrisetmike's Avatar
1967 26' Overlander
Haute-Aboujagane , New Brunswick
I don't know if this is what you are looking for but here is a photo I found of our pocket door.
ID:	359959   Click image for larger version
chrisetmike is offline   Reply With Quote
Need stove for 1967 international Overlander JacqueB Stoves, Ovens & Microwaves 0 07-15-2013 02:54 PM
Need Some AC Advice (1967 Overlander) TCHANNEL Furnaces, Heaters, Fireplaces & Air Conditioning 7 06-06-2009 08:40 PM
need help with remodel 1967 airstream ren walker Airstream Trailer Forums 11 10-15-2006 08:15 PM
need help with water heater on 1967 overlander trailer man LP Gas, Piping, Tanks & Regulators 3 08-30-2005 12:04 PM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
