Old 02-12-2017, 02:52 PM   #21
ChuckZ's Avatar
1966 26' Overlander
2012 28' Flying Cloud
Waukesha , Wisconsin
Al,we're at the Land Yacht Harbor on the West side near 94.
ChuckZ is offline   Reply With Quote
Old 02-12-2017, 05:01 PM   #22
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Originally Posted by Mollysdad View Post
If it shorted before the fuse, the fuse wouldn't be blowing, or am I missing something?
I always made a long (10') wire with alligator clips on both ends. It makes testing with a VOM meter easier. The leads on a meter are never long enough to reach all over.
Maybe I wasn't clear. The positive leads go to the circuits which are separately fused. If the short was on the other side of the positive fuse, the positive fuse would be blowing. So my coclusion was that the negative fuse was blowing because some positive circuit with no fuse, or a larger fuse, was shorted.
Al
Old 02-12-2017, 05:22 PM   #23
If Chuck's trailer is wired like the diagram, the short almost has to be in the TV 7 way or converter wiring or the converter itself. Follow the wire from the positive fuse to the distribution circuit breakers. The two wires leaving the bottom go to the 7-way and the converter.
Al
Old 02-12-2017, 05:36 PM   #24
Just thought of something else. It looks like the fuse on the left is the battery positive and the fuse on the right is the converter positive, or vice versa. What are the value of those fuses? The depending on the model, the converter could source as much as 60 amps. Depending on the battery or batteries, more than 30 amps in the negative lead could be normal.
Al
Old 02-13-2017, 03:27 PM   #25
newsgauger's Avatar
1976 Argosy 28
Milton , Ontario
Update Us...
Hi chuckz,
How are you making out on trouble shooting the blowing fuse?
Chris
newsgauger is offline   Reply With Quote
Old 02-14-2017, 08:38 AM   #26
ChuckZ's Avatar
1966 26' Overlander
Problem solved! As tends to be the case in 51 year old trailers, lots of jury rigging goes on. Some nucklehead (read me) ran a wire under the battery hold down when I was wiring the new power jack last fall. It had managed to wear through and was shorting everything out. All of the trouble shooting suggestions helped to isolate this. Stand by for the next panic. And I'm sure that there will be one. Thanks again to everyone for your help and in particular to Ted Ettel at Land Yacht Harbor in Melbourne. If you're ever in the Melbourne area and need help, he's your guy. You'll recognize him right away. He's Uncle Sy's twin brother.
12v
12V Power Plug in for 12v T.V. Undertaker Electronics & Connectivity 12 09-10-2016 08:53 AM
Help, help i need somebody help socool69 Hitches, Couplers & Balls 9 12-09-2014 05:24 AM
LCD Tv has a 12v converter... Can I use it on 12v? Keyair Audio, Video & TV 6 05-11-2010 03:40 PM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 10:58 AM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
