Old 02-06-2013, 08:56 PM   #1
Mimishouse's Avatar
1966 26' Overlander
Belhaven , North Carolina
Looking for leaks
Several people have told me to fix the leaks as one of the first repairs on the project. I have only one that I see, am I missing something? Shouldn't there be a visable sign where there's one? The third pic is in front of the door, where the stove vent fan leaks. I can stop the leak(I think) not sure about fixing the rot of the floor.
ID:	178428   Click image for larger version
Mimishouse is offline   Reply With Quote
Old 02-06-2013, 09:00 PM   #2
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
It's rare to only have one, typically you will find some up front and some in the very back.
But I did see a 70's safari once with only one leak by the door. So maybe you are lucky.
ddstech is offline   Reply With Quote
Old 02-12-2013, 04:18 PM   #3
Mimishouse's Avatar
1966 26' Overlander
Unfortunately, you were right. There are several leaks, but not from the windows. I checked them out after a rain the other day. Now, to figure out how to go about fixing the rotten spots. Thanks
Old 02-12-2013, 05:47 PM   #4
Baltimore , Maryland
check under the bathroom module. Unfortunately there is rot there too.
Old 02-14-2013, 09:44 AM   #5
Mimishouse's Avatar
1966 26' Overlander
Am I understanding it right, that if I remove the belly pan, I will be able to see my plywood subfloor?
Old 02-14-2013, 04:06 PM   #6
Yes, after you remove the moldy, dirty, mouse arranged insulation.
