Old 09-30-2010, 03:52 PM   #81
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
No tailights
now I see why my taillights did not work
I have found two great looking 7" led lights...should make a bug difference.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 09-30-2010, 06:21 PM   #82
rideair's Avatar
Let me see what I can do about scanning the sales info. I found mine out on eBay back a few years ago. Has pics of the inside/new features/list of standard-options/etc...
If you look around they're out there.
Paul Waddell
rideair is offline   Reply With Quote
Old 10-01-2010, 10:13 AM   #83
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Got many more little things done this week, some heavy rain held me back on others.
The wood is looking better inside, I am working on a couple of small leaks, go the worst one fixed.
AIR #005
retired!
Old 10-01-2010, 01:31 PM   #84
1967 22' Safari
1978 25' Tradewind
NEW LENOX , Illinois
Alan,
This is like, way off topic, but, I got a question for you. I have a '67 21 ft. Safari that I have done a ton of work to and enjoyed the project. But I want to upsize to a 27 footer. Grand kids coming and I'll need the room. I also want a grey tank. And, I don't want the cheap vinyl coated wood work of the 70s trailers but I do like having the grey tank plumbing done for me tho that is not a show stopper. I don't want to completely replace the interior or do a frame-off resto. And I have a pauper's budget... So, here's the question - based upon your earlier trailer projects, what year to get? Late 60's? Late 70's? or Early 80's?
Thanks, John H
johnhh is offline   Reply With Quote
Old 10-01-2010, 04:24 PM   #85
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
70s after 1970 that is have vinyl inside laminate. A larger 70s trailer though is easy to find and usually there are enough to get you a deal on one. I liked the two I had, but needed to downsize and took the opportunity to go 60s and get the "real wood"
I am not sure what year grey tanks were added, but I know all the mid 70s had them.
You can easily find that out here. After 1982 the aluminum is different as I recall and not as easily polished if you want to do that.
The good thing is the vinyl stuff does not take any maintenance, and hold up if its kept clean.
So its a trade off.
Check the vintage airstream site where the listings of all the trailers are, with their specs.
AIR #005
retired!
Old 10-01-2010, 04:28 PM   #86
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Plumbing!^%$
Ok now I can get back to complaining! Not really, but I managed to finally fix three leaks at the rear, and the two fron valves, and the pipe that runs through the living room ( though I don't like the hose clamps getting in the way of the pipe cover that matches the wall).
So I slowly turn the water on....and the under counter water filter is cracked at the bottom and frozen on to the fittings. And a small vertical rubber hose next to the couch is leaking.
Seems like its fix one find two.
(*&^%$#@@#$^&*( if you know what I mean!
AIR #005
retired!
Old 10-01-2010, 04:32 PM   #87
So its a trade off.
Airstrean started using "gray" tanks in the 1974 and up models.
1973 and older models had black water tanks, only.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-01-2010, 08:07 PM   #88
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
HE'S THE MAN...HE KNOWS OF WHAT HE SPEAKS!Thanks Andy for clearing up my senility
AIR #005
retired!
Old 10-02-2010, 01:17 PM   #89
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Got a little done today in the absolutely gorgeous Fall weather.
New LED tail lights installed and working.
Found two log-o-matic type chairs. Don't know what brand they are but they are very light and very sturdy when set up. Great find off CL.
ID:	112161   Click image for larger version
AIR #005
retired!
Old 10-07-2010, 05:55 PM   #90
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Soaked the jack stand parts in Blaster for a few days, they now turn and adjust nicely.
So where do they go? I see the frame in the rear, but can't quite tell where in the front.Should I measure in from the sides?
-Got the last two inside lights working, the aircraft swivel lamps in front.
-Back to the plumbing fix on the weekend. Hope to get it done for my trip in two weeks.
-Ordered a few small but needed Inland Rv parts- cabinet latches, etc.
AIR #005
retired!
Old 10-07-2010, 08:01 PM   #91
Lothlorian's Avatar
Loganville , Georgia
Alan where did you get your LED tail lights. Did you buy them around the Atlanta area?
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 10-07-2010, 09:21 PM   #92
That chair was once available from Airstream, many years ago.
I have a couple of them.
Neato for sure.
They are called "Legomatic".
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-08-2010, 08:19 AM   #93
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Brian
GOT EM ON EBAY- 36.00 the pair. They have a nice larger rubber gasket behind them which I think will be helpful.
The log-o-matics were a local craigslist find, they had been on there a long time, so I was lucky they were still for sale.
AIR #005
retired!
Old 10-09-2010, 04:12 PM   #94
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
added the rear bumper camlocs that hold the hatch closed. Fixed the rear access door lock..it works.
4 inside overhead bin latches, and one more plumbing leak fixed.
AIR #005
retired!
Old 10-12-2010, 11:51 AM   #95
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I looked thru the manual and it does not show my extra - side battery door. Does anyone else have one? I am thinking of removing the tray as we don't boondock much if at all.
I could use that space as storage with the outside access door.
The rear battery tray will remain.
AIR #005
retired!
Old 10-14-2010, 10:45 AM   #96
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Git ion the plumbing again, fixed two leaks, again found two more. Need a hot water heater as the tank is leaking, and the front water storage tank will need repair.
Plumbing is on hold until I can get a handle on doing the PEX redo. Also pulling out the gaucho and some other items to fix the two soft floor areas that have gotten wet.
AIR #005
retired!
Old 10-15-2010, 12:04 AM   #97
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Alan
I have replaced all the plumbing on my 66 TW with Pex. A tool that is essential is a crimping tool from Lowes or HD for $25. It will crimp both 3/8 and 1/2 using a pair of 10" vice grips.
My water tank patch (by the PO) came loose, so I got a wet floor. I patched the tank and it came loose, so I got a wet floor again. I don't want a third wet floor and I understand that patching the polyeurathene tank is very difficult (it needs to be plastic welded). I decided to replace the tank and now carry the patched tank in the back of my truck for boondocking.
Dan
Old 10-15-2010, 08:21 AM   #98
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Thanks for that heads up. I will be adding a water tank to the wish list.
AIR #005
retired!
Old 10-16-2010, 06:11 PM   #99
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
the trailer had this weird 7 pin connector and a 4 pin hanging off it. The 4 pin worked.
I cut off both, to wire a new 7 pin to plug into the truck.
So far it does not work. I managed to get the license plate light to flash and one marker light to come on.
Wit the 4 pin the turn signals and brake lights worked. So I am definitely screwing up the wiring somehow. Back at it tomorrow.
Does anyone know if the schematic that says the black on the truck side goes to the blue on the trailer, and the blue on the truck side goes to the yellow on the trailer; is right?
I printed that out after trying to match the colors on my own which did not work.
AIR #005
retired!
Old 10-16-2010, 07:42 PM   #100
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
Alan
If you had the flat 4 pin working,but trouble when the 7 pin was wired, the short or problem is probably with the blue charge wire or the yellow brake wire(I think the colors are the same for 64 & 65). Try wiring your new 7 pin first with just the 4pin stuff ie running stop and turn lights, and leave the brake and charge line disconnected. If that works ok and it should, then connect your yellow brake wire if you loose all your lights again then you know where the trouble is.
Just remember the 7 pin is not wired the same as it was but changed to fit your truck.
Green are running lights Brown rt turn red lft turn Black is stop (which your truck wont have) white is ground. Thats it on mine but make sure yours is the same before connecting!!!
Hope this makes sense
Kevin
kevinb is offline   Reply With Quote
1966, 1966 overlander, bunk bed
A/C for 1966 Ambassador law1966 Member Introductions 1 07-24-2011 09:24 PM
1966 airstream eBay Watch Airstreams on eBay 0 03-26-2010 06:40 AM
1966 airstream eBay Watch Airstreams on eBay 0 03-19-2010 06:10 AM
1966 airstream eBay Watch Airstreams on eBay 0 03-01-2010 07:30 PM
1966 TradeWind 66TradeWind 1959-69 Tradewind 2 03-18-2002 07:09 AM
