Old 12-06-2007, 06:38 PM   #1
1968 26' Overlander
Stevensville/Fort Fun , Montana
jack stands
Where is the best and safest place to put my jack stands under my trailer when I am working on it. Right now I placed 6 of them under the trailer and it doesn't fell as steady as I would like it.
out4trout is offline   Reply With Quote
Old 12-06-2007, 06:43 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Why not just run the trailer up on a ramp. If you need one axle free, run the other one up on a ramp.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
wkerfoot is online now   Reply With Quote
Old 12-06-2007, 06:59 PM   #3
drag'nwagon's Avatar
1970 23' Safari
1956 26' Cruiser Overlander
Lambertville , Michigan
There is really only one good place to jack an AS. Jack it up, drop the tongue and put the stands under the axle mounting plates.
Dave
TAC# MI-1
Operation "Save Rudy" Strike Team (charter member)
Yes, I am still working on it.
drag'nwagon is offline   Reply With Quote
Old 12-06-2007, 10:34 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I agree with Bill on this one. You can make some ramps out of wood or use the lego type levelers (Lynx) and create a stable work area. Safety First!
Richard
azflycaster is online now   Reply With Quote
Old 12-14-2007, 09:48 PM   #5
1968 26' Overlander
Hey thanks for the info the ramp idea is working a lot better.
Old 12-15-2007, 06:50 AM   #6
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Also, you can leave the trailer connected to the tow vehicle, and set the parking brake on the tow vehicle, and lower the tongue jack until it takes part of the tongue weight. This will help eliminate back-and-forth rocking, if you have to have both wheels on one side off the ground.
Old 12-15-2007, 09:06 AM   #7
LHall's Avatar
2020 30 Globetrotter
Phoenix , Arizona
Wood Blocks are the way to go. I made ramps and used the triangle pieces that were cut off to make wheel chocks to keep the trailer from rolling off of either end of the ramp. They worked great for my axle change.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
LHall is offline   Reply With Quote
vintage jack stands pcasa Jacks, Stabilizers, Lifting and Leveling 10 08-09-2007 07:18 AM
Use of jack stands results in crushed propane line ghatfield Hitches, Couplers & Balls 9 06-25-2007 07:02 AM
using 6 jack stands. rama777 Jacks, Stabilizers, Lifting and Leveling 7 11-30-2006 04:20 PM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
'70s era TV stands/mounts Safari Tim Interior Restoration Forum 0 07-05-2003 05:24 PM
