Old 09-21-2009, 05:32 PM   #1
1968 26' Overlander
Del Rio , Texas
International Package?
My 1968 Overlander is an "International" What makes this different form other packages available during this time?
68-Ovrlndr is offline   Reply With Quote
Old 09-21-2009, 06:55 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The International was an upgrade from the base model. Here is a link to the specifics for your trailer along with the prices: http://service.airstream.com/files/l...58252aedd9.pdf
Richard
azflycaster is online now   Reply With Quote
Old 09-21-2009, 07:02 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Hmmm, the information I have says the International badge was not available until 1969. But I could be wrong. I believe starting in 69 generally the smaller trailers were Land Yachts and the larger Internationals. The exception was the Overlander which in 69 was available as a "Deluxe Land Yacht" and an "International Land Yacht". Generally Internationals had more bells and whistles. I welcome correction.
Old 09-22-2009, 12:20 AM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Lumatic!
The International Package was introduced during the 1950s as an upgrade over the standard Land Yacht trim level. It appears from information on the Airstream corporate site that the International package was first offered in 1958. The contents of the package changed somewhat from year to year and there could be slight differences in content based on model of coach to which it was applied. In 1980, International became a separate model rather than a package that could be added as an option to nearly any Airstream in the fleet.
Kevin
Kevin D. Allen
AIR #827
Old 09-22-2009, 07:27 AM   #5
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
Originally Posted by overlander64 View Post
Greetings Lumatic!
Kevin
Thanks for the info Kevin!
ID:	87562   Click image for larger version
safari62 is offline   Reply With Quote
Old 09-22-2009, 07:51 AM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
I still have never seen or heard of a 70s Tradewind (or other smaller trailers) that is other than a Land yacht or a 70s Sovereign (or other larger trailers*) that is other than an International. Has anyone? Could it be that until 69 International and Land Yacht were trim packages, but 69 to 1980 (when the International model came out) smaller models were only produced as Land Yachts and longer models only as Internationals?
*other than 1979 Overlander
Old 09-22-2009, 09:24 PM   #7
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings Lumatic!
Here is what I was able to find out through a cursory check on RJ Dials Archives:
1978 Tradewind International (Notice multi-color badge along belt-line)
1978 Caravanner International
1977 Tradewind International
1977 Caravanner International
1977 Overlander International
1976 Caravanner International
1976 Overlander International
1975 Overlander International
1974 Safari International
1974 Overlander International
1973 Safari International
1973 Tradewind International
1973 Overlander International
1972 Overlander International
1970 Caravanner International
1970 Overlander International
1971 Overlander International
I suspect that part of the reason that there are fewer smaller coaches with the International package may have something to do with the target audience for the smaller coaches where cost consciousness may have played a role. I also seem to remember reading some document at some point that indicated after 1965 the International package was only offered on tandem axle trailers.
Kevin
Kevin D. Allen
AIR #827
Old 09-22-2009, 10:36 PM   #8
Lumatic's Avatar
1993 34' Excella
Images: 16
Thanks for posting the pictures I enjoyed them even if you broke my bubble. But I think I finally have the Airstream system figured out now. The answer seems to be there is no system and Airstream is a tricky rabbit.
Old 09-22-2009, 10:49 PM   #9
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings Lumatic!
You are so correct . . . it is VERY dangerous to use the words never or always in regard to Airstream or Argosy products particularly those that are more than 20 years old.
Kevin
Kevin D. Allen
AIR #827
What was included in the SE package? cbgenrich 2007 Safari SE 8 05-03-2009 08:13 PM
What's included in the A/V upgrade package? shimmy Audio, Video & TV 6 10-02-2008 10:22 AM
AV package random 17 2006 - 2010 International 3 08-06-2008 08:58 AM
LS Package Double D Buyer Guidelines 11 01-24-2006 06:19 PM
Help (hopefully!) with the solar package :confused: Rhodie Generators & Solar Power 4 12-10-2004 08:22 PM
