Old 01-25-2014, 10:23 PM   #1
Chelan , Washington
Help? What is this?
Is this a 1966 Overlander (International)?
Name:	2014-01-25 17.38.13.png
Name:	2014-01-25 17.37.30.png
Does it have much value? Inside is a "project".
1stairstream is offline   Reply With Quote
Old 01-25-2014, 10:46 PM   #2
Chelan , Washington
Here are a couple more
Old 01-26-2014, 02:07 AM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Help? What is this?
Greetings 1stairstream!
There is a value in virtually any Vintage Airstream, but that value is tempered by condition and to a lesser extent the region of the country where that trailer is located. One of the most frequently mentioned guides to value determination for Vintage Airstreams is the Price vs. Condition guide. The photos posted do indicate that it is a 1966 through 1968 Overlander International.
There is one unique item on the 1966-1968 Airstreams that can pose difficulties in restoration, and that is the Corning Tempered Glass Windows. Should any of the windows be missing or have Plexiglass or Lexan replacements, the costs can escalate quickly. The situation is better today than it was a few years ago when the only source for replacement window glass for a 1966-1968 Airstream was from a salvaged trailer; today, reproductions are available from several sources. Other than the Corning Tempered Glass Windows and their unique operators/latches, the balance of the 1966-1968 trailers are typical Airstream construction.
In addition to the Price vs. Condition guide, the Volunteer Inspectors' Checklist mentioned on the Airforums home page can also help you to assess the trailer . . . there also may be a volunteer inspector located near the trailer who could help you assess the trailer.
The biggest issue revealed by the photos is that the Plasticoat has failed and is particularly bad on the endcaps and upper body panels . . . something that is quite common on "as-found" Vintage Airstreams. Another item of concern is that the LP tanks are missing. Missing tanks aren't a huge problem, but if you want Worthington Aluminum LP tanks that can be polished to match your Airstream, the cost for replacements can approach $500 depending upon size of tank chosen (I purchased 40 pound tanks for my Overlander rather than the more "standard" 30 pound tanks for greater travel time between refills).
Good luck with your investigation.
Kevin
Kevin D. Allen
AIR #827
Old 01-26-2014, 07:59 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
As it sits, just from the photos and years I think a starting figure would be $3000 + or - depending on the condition of what you don't see in the photo. Are you asking from the perspective of resale, investment, or restoration?
I would add to the above one of the first things that will need to be done is replace tires and axles $2000 - $2500. You can also expect to replace all major appliances if they are original, $2000 if you do it yourself. A restored mid sixties should be worth $15 to 20K. Generally speaking, you won't make money on a restoration but should be able to break even. Prices are going up so if you just sit on it and prevent further deterioration you should make money.
Airstream had technically 3 but actually 2 trim levels. In 66 "Land Yacht was a trim level. Much later the name of a model The International had all the bells and whistles, the Land Yacht slightly less so.
If your trailer is 26 feet long (hitch to bumper it is an Overlander. If it is 28 feet long it is an Ambassador. Shorter Aistreams are generally worth more than longer Airstreams.
Old 01-26-2014, 08:16 AM   #5
1977 Argosy 24
Milltown , Wisconsin
According to the serial number, it's a 26' International model 1967 made in California with a double bed.
ventport is offline   Reply With Quote
Old 01-26-2014, 08:31 AM   #6
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Right as Rain
Ventport is correct! The I26 = International trim level 26 foot Overlander and the 7 is the mfg year. S = Santa Fe Springs plant the final three numbers 715 is the production number for that trailer. Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
