Old 07-27-2020, 07:15 PM   #1
Diamondhead , Alaska
Help Identifying
I was gifted this airstream and not positive on year. Can anyone help?
Chtalley08 is offline   Reply With Quote
Old 07-27-2020, 07:41 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I'll start off, although others surely know more than I.
From your photo:
I = International trim level
27 = 27' long ball to bumper which is the Overlander
9 = Would signify a 1979 model year
J = Built in Jackson Center, Ohio
Here is a link to the Airstream Inc webpage that decodes serial numbers. I can't make out your photo entirely, there seems to be missing digits in your serial number tag.
https://www.airstream.com/owners/doc...ments=pre-1980
Hope this helps. Front, back, sides photos would be helpful.
David
WBCCI #8607
VAC Region 11
See my 1969 Globetrotter 21' Renovation Project:
In Knowledge Base
See my 1966 Trade Wind 24' Reno Project:
In Knowledge Base
See my 1975 Overlander 27' Improvement Journal:
In Knowledge Base
See our 1976 Sovereign 31' Renovation Project:
In Knowledge Base
Old 07-27-2020, 07:53 PM   #3
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
Here's more help: http://vintageairstream.com/photo-ar...overlander-27/
Also betting a 79 overlander built in Ohio
1964 Overlander | 2020 Mercedes GLE
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 07-27-2020, 07:59 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I would expect a T or D in the VIN to define the bed layout. I believe that this is a 1969 Overlander because the Production Sequence Number is only 3 digits. In 1979 it would have been a 4 digit number.
The most significant intensifier on the 69 model is the front wing windows. The windows in 1969 have 3 square corners while all of the 70s wing windows have 2 square corners
Richard
Old 07-29-2020, 08:37 AM   #5
Thanks everyone for the help. It seems based on the windows as mentioned having 3 square corners it would be a 69.
Old 07-29-2020, 07:22 PM   #6
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Yep, that is a 1969, the only year with those style windows. My son has a 69 Globetrotter 21' with the same windows. Replacement ones are hard to get.
David
Name:	1009 Interior Front (Mobile).JPG
WBCCI #8607
VAC Region 11
In Knowledge Base
In Knowledge Base
In Knowledge Base
In Knowledge Base
Old 07-29-2020, 11:52 PM   #7
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Southeast , Michigan
Images: 41
Yes 1969, but apparently a typo on the serial number where they left out the "T" or "D". Rare, but I've seen similar SN anomalies before, since they were stamped by hand. I do not believe that Airstream added a second plaque with the serial number and weight information near the front streetside corner until 1971, so no double checking there. There may be a facsimile Warranty Certificate glued to the inside of a closet door that could be checked for the "T" or "D". The serial number might also be stamped into the tongue of the trailer. They did this some years, but I am not sure which ones.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
I need help identifying these rims NatchezBear Wheels, Hubs & Bearings 4 11-02-2008 06:31 PM
Help with Identifying Silver Threads Off Topic Forum 7 08-06-2007 09:56 PM
Help Identifying Trailer therealtoddster 1960 - 1965 Safari 3 05-15-2007 07:02 PM
Need help in identifying this Airstream JimGolden On The Road... 10 01-01-2007 01:56 AM
Need help identifying old Airstream! KY Girl Our Community 3 12-12-2002 06:16 PM
