Old 03-07-2017, 11:04 AM   #1
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
Frame dimensions
Wanting to add a 30 gallon gray tank just behind the axles.
Note sure if this one will fit:
http://www.tank-depot.com/productdet...x?part=R-RV24W
Does anyone know the frame depth and member spacing (longitudinal and transverse)?
BambiTex is offline   Reply With Quote
Old 07-15-2017, 10:48 PM   #2
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
BT
I have a 66 Tradewind, very similar to your 67 Overlander, and I am working on my frame now. You can see my thread under 66 Tradewind. The main rails are about 57" apart. The floor joists are 24" apart. There may be a cold air return duct in the way that could cause some problems.
Send me your email address and I can send you lots of frame photos.
Dan
TouringDan is online now   Reply With Quote
Old 07-15-2017, 10:49 PM   #3
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
BT
The frame depth is 5".
Dan
Old 08-14-2017, 01:14 PM   #4
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Ending up going with a custom tank
Sloping bottom, in bay behind rear axle.
Name:	Gray tank flange.jpg
~1988 32' Frame dimensions Timbojr Repairing/Replacing Floor &/or Frame 0 03-10-2013 12:44 PM
Beatrice era frame experts if you please. Odd frame issue Kevin245 Repairing/Replacing Floor &/or Frame 5 08-25-2012 09:55 AM
Frame Rail Sectional Dimensions JimGolden Repairing/Replacing Floor &/or Frame 20 12-13-2010 08:23 PM
Frame Dimensions? Althea68 Repairing/Replacing Floor &/or Frame 1 10-01-2010 06:26 PM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 05:55 PM
