Old 06-10-2012, 11:22 PM   #1
AR4263's Avatar
1969 27' Overlander
San Betdardino , California
Exterior lights
A new owner of a 1969 27 footer.
Could I turn the exterior lights with out being connected to my truck?
I have two switches on the inside next to the door.
One is for exterior door light and the 2nd one is for???
Thanks for the help
AR4263 is offline   Reply With Quote
Old 06-11-2012, 04:48 AM   #2
Ahem, yasss ...kaff-kaff
egad's Avatar
1969 27' Overlander
Bloomington , Indiana
Congratulations on your purchase!
I'm not sure about your first question but on Betty the switch closest to the door controls the ceiling light near the kitchen. I thought the bulbs were burned out, then I had the bright idea (pun intended) to try the switch on the fixture itself!
egad is offline   Reply With Quote
Old 06-11-2012, 05:41 AM   #3
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
You cant turn on exterior running lights without some type of modification unless you are connected to the tv
Kevin
kevinb is offline   Reply With Quote
Old 06-11-2012, 06:24 AM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Which exterior lights are you asking about? The running lights?
Regarding the second switch by the door, it might be to an overhead light inside. The light fixture itself probably has a switch on it (most do), so the light fixture switch needs to be in the on position, and then the light switch by the door can be used to turn it on and off. Might require a bit of trial and error to figure out which light it controls.
Chris
Old 06-11-2012, 07:18 AM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Running lights no. Little flood light front curbside aka scare light, yes.
Old 06-11-2012, 10:10 PM   #6
AR4263's Avatar
1969 27' Overlander
Thank you.
The dealership near my house got all of the AS on at night and they look so cool!!!
Thanks again. And my adventure has began to restore it.
Old 06-12-2012, 06:25 AM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Originally Posted by AR4263 View Post
Thank you.
It takes a jumper wire on the truck to trailer plug, some people use a blade fuse, you can also use a flasher for that party effect. though at rallies that is usually reserved to help locate you trailer in an emergency.
Aaron
WBCCI #XXXX AIR #2495
