Old 11-16-2017, 05:20 PM   #1
chrisetmike's Avatar
1967 26' Overlander
Haute-Aboujagane , New Brunswick
Bathroom blues
We are now in the rebuilding stage of our Overlander. When we started cleaning the bathroom pieces, I noticed that there is some stains and what looks like a bleached out spot.
Can I paint it the same colour? I really want to keep my bathroom blue but I don't like the stains. What type of paint did you use?
I am not against sending it out to someone else. Who can I call to refinish the bathroom?
Thanks for any help you can give me
Chris
chrisetmike is offline   Reply With Quote
Old 11-16-2017, 05:24 PM   #2
2007 22' International CCD
Try a bathtub/shower stall refinishing company. They can clean and spray an Acrylic/epoxy product that will stand up well. Maybe even in a choice of colors...
Old 11-16-2017, 05:43 PM   #3
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
I used rustoleoum spray paint like three years ago and am still happy with the results. Sanded everything smooth first, washed with soap and water then wiped it down with n propyl alcohol. If memory serves I put down 5 or 6 thin coats of paint to insure durability.Click image for larger version
ID:	299280Click image for larger version
1973Argosy is offline   Reply With Quote
Old 11-17-2017, 04:55 AM   #4
1967 26' Overlander
I will have to check that out.
Old 11-17-2017, 05:06 AM   #5
1967 26' Overlander
Originally Posted by 1973Argosy View Post
I used rustoleoum spray paint like three years ago and am still happy with the results. Sanded everything smooth first, washed with soap and water then wiped it down with n propyl alcohol. If memory serves I put down 5 or 6 thin coats of paint to insure durability.Attachment 299280Attachment 299281
Your bathroom looks good.It also looks like it is holding up to use.
Do you remember the particular type of rustoleum paint, I just googled Rustoleum and several different types popped up.
Thanks for your help
Chris
Old 11-17-2017, 05:13 AM   #6
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
It was just the regular spray can of rustoleum from Lowe's or home depot. Believe the color was "gloss almond"
The Radiator Blues swebster Mechanics Corner - Engines, Transmission & More... 46 08-01-2013 07:47 PM
Over the hill in style - b-day blues Janet H Our Community 30 01-24-2012 05:22 AM
Underbelly Blues hex Belly Pans & Banana Wraps 3 10-24-2002 08:47 PM
Airstream Forum Blues-suggestions for forum usage hex Our Community 18 10-20-2002 11:12 AM
Polishing Blues. TBKP's Overlander Cleaning, Stripping & Polishing 19 10-12-2002 07:57 AM
