Old 09-21-2002, 07:05 AM   #1
LTD93's Avatar
1973 31' Excella 500
Duxbury , Massachusetts
Banks PowerPack for 7.4L Chevy
I am considering purchasing a Banks PowerPack for my '98 Chevy Suburban 7.4L-454 cu. in.
I tow a 1993-34' Limited and spend substantial time on the road. I drive in overdrive with cruise control a lot and I get aggravated at the constant shifting on little rises in the road and the more serious downshifting when in the middle of a bigger hill.
The car has 82,000 miles on it but it is a nice car with all the bells and whistles and I want to keep it until it dies.
I have chatted with some about this addition I am about to do and they say it is a great way to get what you're supposed to have in the 1st place.
Any comments accepted....positive or negative.
Rich
LTD93 is offline   Reply With Quote
Old 09-21-2002, 08:14 AM   #2
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Hmm...My Chevy owners manuals and the sticker on the drivers door says not to tow in Overdrive.
Are you talking about the Banks Turbo Kit or just the kit that opens everything up...Intake, Exhaust, Headers?
I have Gibson headers, AiRaid intake, Borla exhaust and Hypertech chip on my Chevy and it did make a difference. A plus is (to me) it just sounds cool !!, but I am a little o'l Texas boy and we all like rumbling out of our Pick-em-up trucks.
I say bolt them Mod's on and get after it.
For you 02 Cadillac Escalade owners, Dyno-Proven Products is now shipping a Supercharer kit that packs on 100 plus HP putting it at over 500 HP. VROOM..VROOM
Also available for the Chevy 5.7, 4.8, 5.3 and 6 litre engines.
(888) 781-6968
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 09-21-2002, 06:28 PM   #3
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Thumbs up Banks on Silverado
I have a Banks kit on order for my 5.3L SIlverado for the exact reasons that LTD93 quotes; I want to reduce downshifts, especially on all the little ups and downs in our Texas Hill Country. I want to try the Banks rather than trade an almost new truck that suits me in every other way.
In most cases, even a little bit more "oomph" would avoid downshifting, especially that second shift.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 09-21-2002, 08:01 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We too have read & been told never tow in overdrive...
Shari
Old 09-21-2002, 08:10 PM   #5
Contributing Member
Pahaska's Avatar
Tow Haul Mode
GMC/Chevy products with the Tow/Haul mode do not have an overdrive switch, per se. When in Tow/Haul mode (anytime I'm towing), the transmission uses overdrive whenever possible. The only thing changed is the shift points. Overdrive is used just as in Normal mode.
Actually, I can see very little change on fairly level ground. The difference only shows up on hills. The transmission seems to have a memory in that it stays in lower gears longer after negotiating a series of hills.
John W. Irwin
WBCCI #9632
Old 09-22-2002, 08:54 AM   #6
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
My transmission shop recommends to not engage overdrive for towing, regardless of the factory setup. His comment was that he makes a ton of money on people towing with overdrive and not paying attention to the constant shifts. Keep in mind also that the addition of engine power and torque also put higher strain on the transmission if you use this extra power. My feeling is that you should also look at some additional cooling for the transmission, unless you already have taken care of that.
Uwe
www.area63productions.com
Old 09-24-2002, 05:53 PM   #7
sovereign's Avatar
mill springs , North Carolina
alot of it depends on the rear axle ratio too. my chevy c-3500 has 4.56 to 1 gears and it never shifts or "hunts" gear changes. but my 5.3 ,3.73 to 1 silverado hunts in and out of overdrive just pulling a small trailer/golf cart
sovereign is offline   Reply With Quote
454 Chevy timing Tom & Janet Salhus Mechanics Corner - Engines, Transmission & More... 40 11-20-2013 07:12 PM
Banks exhaust brake for Dodge Ram wflorencejr On The Road... 9 10-15-2005 08:26 PM
Safari 28W + Chevy 5.3L/4.10 = Love? docbluedevil 2000 - 2004 Safari 7 10-08-2003 09:51 AM
Banks PowerPack Systems autoist Mechanics Corner - Engines, Transmission & More... 21 03-03-2003 10:03 AM
towing and the Banks Power Pack kooblekidz Airstream Motorhome Forums 11 10-31-2002 12:09 AM
