Old 03-19-2015, 10:42 AM   #1
Chico , California
Are these structural or decorative?
Hi, does anyone know if these aluminum strips that run parallel along the ceiling in my '68 Overlander are structural or purely decorative? If it's not clear from the photo, they are a T shape in section.
Thanks!
Name:	ImageUploadedByAirstream Forums1426783137.519821.jpg
simonavery is offline   Reply With Quote
Old 03-19-2015, 12:12 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
I don't know about the older trailers, but they are definitely structural in my 2001 Safari. They are also where the center roof panel is attached to the side panels.
Al
Old 03-19-2015, 02:09 PM   #3
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
Thanks!
I believe what you see is decorative. What is under it is somewhat structural. When I removed the inner skin of my Argosy, the main structural ribs go side to side. The front to back ribs are more for riveting the inside skin to as well as the trim you see.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 03-19-2015, 02:33 PM   #4
1967 26' Overlander
Richmond , Virginia
Thanks!
I don't think that's factory, it should look like the right side of your pic the whole way. At least that's how my '67 Overlander is (and how all of the pics of originals I've seen are).
See here:
1968 Overlander 26' - Vintage Airstream
Given that the rivets don't line up with how the originals were, it's most likely just decorative, though they probably hold up the wood paneling you see there.
bobzdar is offline   Reply With Quote
Old 03-20-2015, 10:26 PM   #5
Chico , California
Thanks for all the input. You've given me the courage to remove them, as I want to remove the poorly installed veneer, and get back to a cleaner look.
Would like to see how folks have made decorative patches or fixed dents holes scratch desertratt Ribs, Skins & Rivets 15 08-17-2012 08:05 PM
Newbie question - decorative lug covers idmtman Wheels, Hubs & Bearings 9 02-05-2011 11:41 AM
Decorative Plate to Cover Damage? scooterpie Ribs, Skins & Rivets 11 01-25-2008 03:11 PM
Leaks in the decorative molding! frank n'shar Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 12-04-2006 11:20 AM
