Old 01-23-2010, 11:15 AM   #1
1968 26' Overlander
Stevensville/Fort Fun , Montana
A/C problems
I am removing the motor in my 68 overlander and I can't seem to be able to remove the interior fan off of the moter. I can get it to move up and down on the shaft but it doesn't seem like it will come off the rest of the way. Am I missing something?
out4trout is offline   Reply With Quote
Old 01-23-2010, 01:01 PM   #2
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Not sure in your particular situation but I have changed several and they can be stubborn.
I assume there a hex head set screw that you have loosened and it helps to remove it all the way. The set screw can bur the shaft and make it harder to remove.
I think there must be some kind of puller the shops use but for me it is just sticking with it and try not to damage the cage.
PB Blaster on the shaft will help also you can use WD40 in a pinch.
Garry
Old 01-23-2010, 02:05 PM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Not my ears, but
I don't remember a huge struggle when faced with a similar issue on my '67. After removing the setscrew & soaking the shaft with WD-40 & allowing it to soak in, thin-nosed Vice-Grips were clamped to the shaft.
As it was hanging kinda low, the fan blade was then wobbled to & fro on the shaft BY HAND until it freed up.
My success kept me from being tied in a knot...
Tom
Old 01-23-2010, 09:09 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
I have found that older 12v fans can be extremely stubborn. I've had to cut the shaft to get them apart on more than one occasion.
a/c problems groovy1616 Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-10-2009 07:15 PM
JC With Problems, Same Problems Goin Home ncbambi 2008 Safari SE 3 06-23-2009 09:44 PM
Update on Problems Problems pjzuk General Motorhome Topics 4 09-04-2007 06:02 AM
Problems Problems Problems pjzuk General Motorhome Topics 6 09-03-2007 07:25 AM
