Originally Posted by gmshadow
I need the window that is just forward of the door, The top window that opens up, including frame and hinge is 22.5" High and 18.5" wide. Just how the glass could be replaced is not readily apparent. Also need the center vent assembly. 23.25 X 12 inch hole. looks like it just cranks up.
Thanks, Fred
Chewelah! Are you Khan-Do Electric? I saw an AS parked there when we were looking for our AS many months ago.
Welcome to the forums. You'll find helpful information and people here. Use the search function above to look through the threads, as much of what you will need has probably already been discussed - and feel free to ask away.
Pictures - whenever possible post pictures so we all know what you are talking about. There should be a number stamped into the window frame - starts with HEHR ....... That will help in locating exactly what you need. There are a few places that stock vintage parts, Colaws is one (link below)
http://www.colawrvsalvage.com/ or try
http://www.azrvinc.com/
InlandRV has the vent cover if this is what you are looking for:
http://www.inlandrv.com/parts/83179-lens2.jpg
