Old 06-13-2009, 10:01 AM   #1
sbreide471's Avatar
1969 27' Overlander
woodinville , Washington
Cool '69 27ft overlander
does anybody know the wiring diagram on the trailer plug or were to get the femail plug that gos to the trailer frome the truck for a 69 overlander 27ft im trying to restore it and does the wheels stop when you back up or does the break wire need to be pulled in order to back up
thanks scott
sbreide471 is offline   Reply With Quote
Old 08-27-2009, 07:48 AM   #2
1969 27' Overlander
Billings , Montana
seven way wire diagram
I found this7wayplug1966-81.pdf
gentryBC is offline   Reply With Quote
Old 08-27-2009, 09:30 AM   #3
Registered User
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2014 25' Flying Cloud
Palmer Lake , Colorado
this may help http://www.airforums.com/forums/f37/...tor-48969.html
or this http://www.airforums.com/forums/f37/...ams-38170.html. Look at the 7-way connector diagram, second set of graphics down the post. It will tell you the difference from the standard modern tow vehicle pin-out to the Airstream pin-out.
Zep
Old 08-29-2009, 08:35 PM   #4
mbmbstreamer's Avatar
2006 25' Safari SS SE
1969 27' Overlander
Martinez , Georgia
I just replaced my umbilical and female connector in the wall of my 69 Overlander. I replaced the wall connector with a metal female round pin connector made by Pollak. It fit the holes identically and I wired it identically with OEM.
I modified the umbillical wiring by connecting the appropriate wire (regardless of color) to the applicable pin. I had the black wire (from the truck) in the center - charge line. I connected the blue line from the truck to the yellow wire on the trailer and the yellow wire from the truck to the black on the trailer.
I made a diagram and matched the truck connector to the trailer. The metal Pollak female plug looks great, but I did put a sheet of gasket (rubber) between it and the aluminum skin. I also used stainless screws. Make sure you take careful notes before disassembling and don't lose any grounds. There are several connected to the back side on each of the mounting screws.
mbmbstreamer is offline   Reply With Quote
Old 06-21-2010, 08:37 AM   #5
1969 27' Overlander
Sunny Skies , Rockies
mbmb.
I am looking at the same setup wiring as you have described. I ordered the parts and will be ready to wire it as soon as I receive them.
From your description of the modified lines, are the ones you mentioned the only switches you made? I am in the process of making a similar diagram and am collecting all the info prior to the actual wiring.
My TV is a 2009 5.7 Tundra with the standard 7 pin.
If you have any other info to pass on I would appreciate it.
Marcello is offline   Reply With Quote
Old 06-24-2010, 05:57 PM   #6
1969 27' Overlander
Martinez , Georgia
That was it. I would still go through all the functions and make certain they work as expected. That's how I found my problem. Trial and error was how I solved the issues.
Matt
WBCCI # 3518
TAC# GA-6
Old 06-25-2010, 08:53 AM   #7
1969 27' Overlander
thanks.
that is what I did and made sure to document everything. When I can some time I will post the actual graphic diagram.
cheers
NEEDED: Two front windows for '71 Overlander jesse_kevon Windows, Doors, Locks & Vents 4 05-30-2015 09:26 AM
Need Door for 1961 Overlander BentMetal 1960 - 1964 Overlander 9 07-28-2011 04:36 PM
Need Refrigerator Compartment Door for 1972 Overlander jazz1945 Exterior Storage Compartments & Access Doors 1 05-30-2011 02:50 PM
1969 AIRSTREAM 27ft Overlander eBay Watch Airstreams on eBay 0 04-10-2011 03:50 PM
'61 Overlander Rescue BentMetal 1960 - 1964 Overlander 1 03-20-2011 02:43 PM
